Rag joint steering coupler won't move
I am trying to replace my rag joint due to sloppy steering. I have removed the 2 bolts on the sides and the one on the shaft. I cannot get the shaft to move up at all in order to get the old rag joint out. Any advice??
I would spray some Kroil on the splines and let it soak in a day and you can try to spread the coupling at the slot in it but that would be to try and slide the flange up, you're better off removing the box, then clean the rag and check the box.
Jim Shea: "The flex cplg and steering column flange connections overlap. In other words, you have to either disconnect and move the steering column rearward into the driver compartment or you have to loosen and tip the steering gear in order to gain sufficient distance to actually get the steering coupling and the column flange to disengage. The way the components are designed, the steering components cannot disengage if just one critical fastener is missing. So if something is not tightened or connected correctly, the operator of the vehicle should have plenty of noticeable steering looseness as well as audible rattles as a warning that something is not right."
Check out his download: http://jimshea.corvettefaq.com/?p=796
