Help with 1970 Convertable Engine Code?
Old Dec 17, 2022 | 10:07 AM
SquiggleBottom's Avatar
SquiggleBottom
4th Gear
Default Help with 1970 Convertable Engine Code?
Sorry about the bad quality, but here are the codes on the passenger side of the block, any help? I Looked at all the decoders to no avail. I believe the first part is 191331213 and then t0602HD.
Old Dec 17, 2022 | 10:26 AM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
From the VIN stamp that is not a 1970 Corvette block
Old Dec 17, 2022 | 10:38 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
The left side numbers are a partial VIN. The right side is the assembly date ( June 2nd) and the following letters are an engine code.
As Ralph said, the VIN does not match a 1970 Corvette. Also the engine code HD is not a 1970 Corvette code.
Old Dec 17, 2022 | 10:42 AM
SquiggleBottom
4th Gear
Thanks and yeah I figured as much. Any idea how to go about figuring out WHAT it is?
Old Dec 17, 2022 | 11:11 AM
Motorvation's Avatar
Motorvation
Try here: https://www.mortec.com/
Steve O.
Old Dec 17, 2022 | 11:12 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
HD is a 69 350/250 2 barrel carb with a TH350 from a A body, nova and big car
Old Dec 17, 2022 | 11:33 AM
gbvette62's Avatar
gbvette62
It's a decent replacement for the 70 base L-48 350. The 69 L-65 is the same basic engine as the 4 bbl L-48, but with a 2 bbl carb and intake.
Old Dec 17, 2022 | 11:39 AM
SquiggleBottom
4th Gear
Wow thanks so much everyone! Appreciate it!
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Just to clarify a tad: HD was used on other years and models (including Corvette) according to the Lime Book (downloadable pdf). The -9- in the VIN seems to indicate the '69 model year but HD was not used for Corvette in '69. Additionally the long VIN seems to indicate this engine was installed in car # 331,213, so which models had such a high production #? Lastly, the T in the engine code indicates it was cast at the Tonawanda foundry. I'm pretty sure that Corvette small blocks only came from the Flint foundry for '69.
To Help with 1970 Convertable Engine Code?
