Carpet install 70 Vert
Old Dec 20, 2022 | 08:57 PM
Hooked4Life's Avatar
Hooked4Life
Default Carpet install 70 Vert
Kind of a 2 weekend project, pulled the old crusty and installed a new ACC molded carpet kit. All I can say is it looks amazing, super happy with the color and loop design. It was a little pricy but I have used ACC before on a 76 Eldorado and was very happy, so I went with them again. I bought the underlay matting as well, and it proved to be a little too thick on the back end, so I did not use all of it. I was very determined to do it right so my advice is to take your time and trim a bit at a time on the edges. Pretty sure I was pulling out the original GM carpets when I started, it was so bad and someone along the way decided to spray die on them to darken the blue. The Arizona sun took it's toll on that. Just wanted to let the community know that the ACC carpet kits are spot on, and you can buy through a number of our vendors. It was definitely a 2 weekend job, so plan accordingly. When i did my Eldorado, it was a 2 hour job, since it was one giant piece and you just rim the edges. The Vette has many separate pieces that all need to be individually perfected.
Old Dec 20, 2022 | 10:18 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Do you know which of their three "quality" levels you got? Their middle level is supposed to be most like GM original but I've only gotten samples.
Old Dec 20, 2022 | 10:24 PM
How Are You's Avatar
How Are You
I’m happy your carpet installation went well.
Old Dec 20, 2022 | 10:27 PM
ed427vette's Avatar
ed427vette
I would like to know which ones to buy as well. I have two 69’s and want to get the best original looking carpets for them both.
Old Dec 31, 2022 | 02:33 PM
Hooked4Life
Finally getting back to this thread. I bought the carpet through Zip, and was Item number I-2153.41 70 w/Auto Full Carpet Set (Loop Design) Interior Color: 68-70 Bright Blue, it had the Mass backing. Also the underlayment set PN I-2266 68-75 Conv Full Carpet Underlayment.
To Carpet install 70 Vert
