Vacuum leaks
Old Feb 9, 2023 | 06:55 PM
Nickster2212's Avatar
Nickster2212
Default Vacuum leaks
What would be a good hose to hook up my smoke machine to check for a vacuum leak on my 1980. This car must have a hundred miles of lines in it.
Old Feb 9, 2023 | 08:10 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Providing the year of your car is always helpful to point you in the right direction. That said, the main vacuum hose, right off the engine's intake manifold that runs to the vacuum tank, is likely the best place to start.
Old Feb 9, 2023 | 08:30 PM
Nickster2212
Thank you
Old Feb 9, 2023 | 10:41 PM
Mooser's Avatar
Mooser
Does the smoke machine put out enough pressure to push through the vacuum system on a vette? I'm thinking you can't really test it under vacuum so you'd have to pump the smoke into the system instead? The main vacuum source is pulled from the intake manifold, through the filter and check-valve so if you removed the hoses from the check valve and hooked the smoke machine on them I guess it should fill the lines with smoke and you'd see where it was leaking out at the relays or actuators.. I don't think there is any way of making the relays work without vacuum...
Honestly, I'm not sure there's a real benefit to using a smoke machine to test the vacuum system is there? Maybe I'm missing something
https://www.corvette-101.com/vacuum.htm
M
Old Feb 9, 2023 | 10:44 PM
Kingtal0n's Avatar
Kingtal0n
Pressure test the intake. Look up boost pressure leak test. View a few videos to see how its done. On an NA engine its much simpler and easy to do.
You can't rely on smoke because some leaks require pressure to expose. For example intake gaskets may only leak at -5psi or +5psi. Psi can be negative or positive with respect to atmosphere. For example 1" Hg of vacuum is equal to -0.491154 PSI
To Vacuum leaks
