Power steering fluid
Old Feb 17, 2023 | 11:35 AM
Nickster2212's Avatar
Nickster2212
Default Power steering fluid
Should I change power steering fluid on my 1980? I bought this 37 years ago from the original owner. There is no problems with the unit and the fluid is the only one that I have not flushed and changed.
Old Feb 17, 2023 | 01:26 PM
interpon's Avatar
interpon
other than sucking out what you can and refill fresh GM power steering fluid.. a few times over a few runs.. i would leave it alone
Old Feb 17, 2023 | 03:48 PM
sunflower 1972's Avatar
sunflower 1972
If it ain't broke, don't fix it.
Old Feb 17, 2023 | 04:08 PM
Nickster2212
Yes I was thinking the thing.
Old Feb 17, 2023 | 04:23 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I just can't believe in 37 years you never had a leak!
this has got to be a record for these cars!
I agree, don't touch it!
Old Feb 17, 2023 | 04:29 PM
Nickster2212
Only leak kn the car was from the transmission and it was a few drops. I did a filter and gasket replacement and it fixed that.
Old Feb 18, 2023 | 02:19 AM
4-vettes's Avatar
4-vettes
In the 35 years I've had mine. 2 power steering pumps. 3 low pressure return lines. 2 high pressure feed lines, 2 rams and 1 control valve.
And this is fairly normal from everything I read on here over 15 years and being in 3 car clubs at the present and several corvette clubs over the years.
So, I still say, you must have set some kind of record!
Old Feb 18, 2023 | 10:41 AM
lickahotskillet's Avatar
lickahotskillet
Shelf life of oils in the bottle is 5 years. Would you buy a 37 year old bottle of fluid from the parts store to use in your car? Or just wait till it leaks then do the repairs.
Old Feb 18, 2023 | 11:18 AM
REELAV8R's Avatar
REELAV8R
Maybe that's the secret, don't change your power steering fluid...ever.
Old Feb 18, 2023 | 11:22 AM
SteveG75's Avatar
SteveG75
I would not break any on the lines free. Remove the alternator for access and use a turkey baster to remove as much fluid as possible. Refill with fresh fluid. Do that a couple of times and your fluid should be pretty refreshed.
Old Feb 18, 2023 | 11:33 AM
Nickster2212
Yes may do that.
Old Feb 18, 2023 | 02:26 PM
sunflower 1972
You don't need to remove the alternator. Use this or something similar.
Old Feb 18, 2023 | 03:05 PM
Nickster2212
I will use my electric pump to do that. Thank you.
Old Feb 18, 2023 | 03:27 PM
HeadsU.P.'s Avatar
HeadsU.P.
Lots & lots of C3s get their PS flushed on every road trip out and brought back into the garage.
(going to fix that leak one of these days)
Old Feb 19, 2023 | 07:02 AM
C3Highway's Avatar
C3Highway
GM probably never intended for the PS fluid to ever be changed, but they were also probably not expecting a 1980 model to still be on the road 43 years later. I agree with the suggestions to pull the fluid and refill several times. 40 years is a long time.
Any PS system could certainly be excused for developing a few leaks over nearly a half century. So you have been blessed.
I changed out my leaking PS control valve, four PS hoses, and ram cylinder eight years ago and it has been great since. Of course, my `79 was about 35 years old at the time so I count my blessings.
Old Feb 19, 2023 | 09:30 AM
SteveG75's Avatar
SteveG75
Saw this fluid extractor at O’Reilly yesterday. Not cheap but I like the fact that you don’t have fluid running through the pump mechanism, so hopefully, it would be easier to clean and less chance of contamination.
https://www.oreillyauto.com/detail/c...ge+pump&pos=18
Old Feb 19, 2023 | 12:45 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Amazon has the same model for $52.50
Amazon Fluid Extractor
Gonna have to get me one of these!!!
Old Feb 19, 2023 | 01:54 PM
sunflower 1972
And, if you want the top of the line:https://www.skf.com/mityvac/products...cuators/mv7201
To Power steering fluid
