Heater door actuator
Old Feb 23, 2023 | 03:38 PM
wkb2460's Avatar
wkb2460
Default Heater door actuator
Have a 72 non AC car. Looking for the vacuum door actuator on heater box. Not the one that has two vacuum lines, that is for defrost door.
I need the other one that closes off all air when system is in off position. It only has one vacuum line . Searched the web, can't find it.
Hope you guys can help. Thanks
Old Feb 26, 2023 | 03:16 AM
hunt4cleanair's Avatar
hunt4cleanair
Originally Posted by wkb2460
Have a 72 non AC car. Looking for the vacuum door actuator on heater box. Searched the web, can't find it.
Don't think you'll fiind it on the web. Try looking above the heater box!
Old Feb 26, 2023 | 09:22 AM
Mooser's Avatar
Mooser
With the number of people who have removed the heater system someone should have one laying around.
I'm guessing this is the one you're after (I can't help other than putting a picture up there)
Try posting in the parts section
M
Old Feb 26, 2023 | 12:00 PM
wkb2460's Avatar
wkb2460
Old Feb 27, 2023 | 11:35 PM
AGVI Kicks's Avatar
AGVI Kicks
They welcome you!
Old Mar 4, 2023 | 09:58 PM
piste's Avatar
piste
Banned Scam/Spammer
I was in same boat, posted everywhere, contacted all the vendors...it is unobtanium AFAIK. Then I put mity vac on mine to learn it worked fine. Might pull it out when I breakdown the box just to make it look pretty. But don't really matter as no one gonna see it. Have you tested yours?
To Heater door actuator
