Color trim code corvette 1974
Old Feb 24, 2023 | 08:06 AM
sergio1400's Avatar
sergio1400
7th Gear
Default Color trim code corvette 1974
I try to find the good code trim inside paint for my baby corvette 1974 silver on silver, now i spend à lot off Time ans the money to reach the good color
thank you
Old Feb 24, 2023 | 10:21 AM
MelWff's Avatar
MelWff
Interior code is 406 or 407. Look at trim tag on A pillar. This is a source for interior spray dye.
https://www.zip-corvette.com/68-82-i...e-aerosol.html
Old Feb 24, 2023 | 02:25 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Sergio1400, just to add a little more detail to help you in locating it if you haven't already, the A-pillar with the trim tag is where the driver door hinges are. You should see a 2"x3" (50mmx75mm) aluminum plate riveted on the body.
To Color trim code corvette 1974
