Dimmer switch failure
Old Feb 25, 2023 | 12:32 PM
nitan2k's Avatar
nitan2k
Default Dimmer switch failure
Hello, all. My dimmer switch on my 82 failed, it would stay on low beam, and when trying to switch into high beam, the headlights would just turn off. So i replaced the dimmer switch with a new one, and it worked for a week. But then that one failed with the same symptoms as the old one. Anyone know what exactly might be going on here? Thanks
PS: I keep high beams on normally when im driving.
Old Feb 25, 2023 | 02:55 PM
MelWff's Avatar
MelWff
The headlight switch has a circuit breaker and it sounds like you are tripping it. Do you have the original sealed beams? Have you checked for corrosion at the headlight plugs?
Old Feb 25, 2023 | 04:15 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
This.
Plus, have you considered installing headlight relays to take the load off the headlight switch and dimmer switch?
Old Feb 25, 2023 | 10:46 PM
nitan2k's Avatar
nitan2k
Yea I have the originals, I swapped them with some other ones. Where is the circuit breaker exactly? No corrosion at the plugs
Old Feb 25, 2023 | 10:56 PM
MelWff's Avatar
MelWff
it's not serviceable, part of the switch. Exactly what headlights did you install?
Old Feb 26, 2023 | 07:27 PM
nitan2k's Avatar
nitan2k
a pair of these
https://www.oraclelights.com/product...beam-headlight
they have a led ring on the outside that I tapped into the high beam circuit. They also take a H4 Bulb on the inside. Might be the culprit, although I don’t remember if I installed these before or after the first switch failure. I just figured LED doesn’t draw a lot so I can add it to the high beam side.
I can try this: wire the leds to the turn signals, maybe replace the h4 halogen with a led bulb. Do I have to replace the switch too?
Old Feb 26, 2023 | 07:37 PM
MelWff's Avatar
MelWff
a pair of these
H4s all by themselves draw more wattage than the original sealed beams. You need the headlight switch to turn on a relay to feed those lights.
Old Feb 26, 2023 | 09:11 PM
4-vettes's Avatar
4-vettes
Like I said in post number 3. Put in headlight relays!
Old Feb 26, 2023 | 09:31 PM
nitan2k's Avatar
nitan2k
Yea looks like it…. What about LED h4s instead? Really wanna avoid changing the stock wiring, and I was gonna replace them with LED anyway
Old Feb 26, 2023 | 09:41 PM
MelWff's Avatar
MelWff
look at the wattage of the bulbs compared to stock sealed beam. If more it wont work without relays.
Old Feb 26, 2023 | 10:45 PM
nitan2k's Avatar
nitan2k
Ty. I’ll look into it. Anyone have any relay kits they recommend? If I go the relay route I wanna do it with as little molestation of the original wiring as possible.
Old Feb 27, 2023 | 02:45 AM
4-vettes's Avatar
4-vettes
Check out , Mad Electrical. There Web site is very informative and you won't need to moleste your harness much at all. You will be doing your factory wiring and switches a big favour.
To Dimmer switch failure
