My 1978 Vette has started having an issue where if I turn on my bright headlights, it kills the engine. Has anyone else ever had this issue? I have been wanting to upgrade my headlights to the newer brighter headlights, not sure if this will fix the issue, or if I need to try and fix the issue first. Any help is greatly appreciated.
WAG, Check the connections to the distributor coil / module. If you have another one laying around try swapping them. It's possible the highbeams are drawing that extra bit of juice to pull the coil/module down too low.
M
WAG, Check the connections to the distributor coil / module. If you have another one laying around try swapping them. It's possible the highbeams are drawing that extra bit of juice to pull the coil/module down too low. M
I would actually get out a voltage meter and check the voltage at the pos side of the coil.
Start the car - and check voltage from coil pos to ground:
1) With no electrical accessories on.
2) With parking lights only
3) With Low Beams only
4) With High Beams.
It could be a single problem,or several problems.
As the members said...weak alternator...corroded-loose connections..hi amperage radio-speakers...high amperage cooling fans...etc.
You wouldn't be using the HEI 12V wire to supply current to anything else...
would you?
All good points above. Although the holding the wire in your hand idea may be difficult compared to just testing voltage.
what does your volt gauge on your dash read when idling? It should be 14.5 volts. Or very close to that.
Does the volt meter on the dash drop when you turn on your lights?
It shouldn't.
What is your voltmeter doing when this happens? One night, I noticed that mine would drop to 11.5V, and slowly decrease, as the high beams drained the battery. I drove home on low beams, and upgraded to a 150A 3-wire alternator. That fixed my problem, but some more info would help for yours.
@interpon has a thread showing how to rebuild an alternator, which is also a warning on buying rebuilt alternators.
yup exactly what i was thinking..chinesium ac delco junk knocking rpm down compered to oem.
