Rally Wheel Question
Old Apr 9, 2023 | 11:28 AM
MidShark's Avatar
MidShark
Default Rally Wheel Question
The original rally wheels wheels from my car were left outside for an extended period of time, and a couple of them must have had tires on during that time as well. So a couple of the wheels have badly pitted edges where the tire bead contacts it. Would you call this too badly damaged to use? They really look a little worse than the pic shows.
Rich
Old Apr 9, 2023 | 12:52 PM
gbvette62's Avatar
gbvette62
I would try sand blasting them, mount some tires on them and see what happens. Even if they do leak tire shops have a sealer that often works well at sealing tire beads to pitted rims.
Old Apr 9, 2023 | 12:58 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Once clean, filling the pits and skimming with JB Weld would also help ensure a seal is possible and better the look of the finished rim area.
Old Apr 9, 2023 | 01:04 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
This may be a long shot:
How about putting a "skim coat" of quality Silicone Rubber (for doors and windows)
on the pitted area.
Put just enough to fill in the pits.
Don't put it on the area you will see if a tire was mounted on the rim.......
you want the paint to stick on the uncoated area.
Let the Silicone rubber cure for a couple days....then paint the rims.
Old Apr 10, 2023 | 06:01 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Silicone rubber? You really don't want the tire to slip on the rim. I've seen this many times on motorcycles. A hard launch and the rim turns faster then the tire.
this can cause a bead seal loss under acceleration or hard braking.
This is VERY dangerous.
I think filling the pits with JB weld or similar would be better. But myself after looking at that photo of the rusted rim. I wouldn't think twice about buying new rims. This is a safety item I just couldn't ignore.
Old Apr 10, 2023 | 06:31 AM
sleepchamber's Avatar
sleepchamber
I agree, why risk it.
To Rally Wheel Question
