Disabling the power antenna?
Old Apr 12, 2023 | 02:09 PM
errant_rider's Avatar
errant_rider
Default Disabling the power antenna?
So I just got an '82 and it has a power antenna. I'd actually prefer it to stay down, and I'll absolutely NEVER use the radio. So I'm wondering if there is an easy way to disable it from going up as soon as the car starts and the (aftermarket) radio turns on?
Old Apr 12, 2023 | 04:52 PM
Bikespace's Avatar
Bikespace
Always nice to meet a like minded individual! I've removed the antennas from both of my C3s (well, one yeeted itself right out of the car, but anyway).
Your (aftermarket) radio is triggering a relay that supplies power to the antenna motor. I'm not exactly sure where these components are in an 82, but you should be able to follow a wiring diagram to find them (perhaps the relay is under the center console, and pulling that would solve your problem?). There is also a connector for the antenna, perhaps behind the carpet in the package shelf.
You can find a wiring diagram here:
http://wordpress.keystonestatecorvet...m/?page_id=118
EDIT: I say "should", but I looked at the 82 wiring diagram, and could find no mention of the antenna, so perhaps it is incomplete. If you set your aftermarket radio to a different mode, (AUX, or BlueTooth, for example), does it retract the antenna? If so, you just need to find the wire from your radio that is being used, and disconnect it.
Old Apr 12, 2023 | 05:05 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
keep the radio turned off.
Old Apr 12, 2023 | 05:09 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
unplug wires at motor
Old Apr 12, 2023 | 05:20 PM
errant_rider
which wire? Where? Can you provide some more details?
Old Apr 12, 2023 | 05:28 PM
Bikespace's Avatar
Bikespace
@interpon's 79 does not have a connector. 80-82 does (and perhaps late 79?). Anyway, some photos are here that may help find a connector. You can also find a picture of the relay online if you search for the part. The wire bundle in question is green, white, and gray.
I cut all of that out of my 80, so I didn't bother with connectors. Unfortuntely, I also didn't take any pictures, and the muffler needs to be removed to get to the base of the antenna.
https://www.corvetteforum.com/forums...na-wiring.html
calwldlife's Avatar
calwldlife
St. Jude Donor '22
at the antenna there is a plug.
3 wires I think.
under car drv side at/on ant motor
Old Apr 12, 2023 | 05:34 PM
Bikespace's Avatar
Bikespace
Here's a better diagram.
If you can find the relay in the car somewhere, you can disconnect the three wires there, instead, if you can't get past the muffler.
https://www.corvetteforum.com/forums...r-antenna.html
Old Apr 12, 2023 | 06:38 PM
gbvette62's Avatar
gbvette62
I believe the relay is in the rear storage compartment.
Old Apr 13, 2023 | 05:18 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Yes. Unplug the relay. It is in the passenger side rear storage compartment.
Old Apr 13, 2023 | 07:11 AM
BKarol's Avatar
BKarol
and will look like this
Old Apr 13, 2023 | 08:15 AM
speedreed8's Avatar
speedreed8
Another idea. I pulled the drivers side console panel, found the yellow trigger wire from the radio to the relay and installed a small rocker switch mounted on the side panel. I can control when it goes up or down.
To Disabling the power antenna?
