Hey Everyone,
I got a 69 427 nom with numbers matching muncie trans, Repo 621 bellhousing. I bought a flywheel and clutch/pressure plate kit from summit.diaphragm, stock replacement
im prepping to break in the cam however i cranked the engine with the clutch pressed in and the car moved forward.....
i adjusted the clutch rod to the end of the rod, same problem.
I read that the ball might be too short with repo flywheels, it was 1.5 long
i put a 3790556 in today, which is 1.78 long
i can now get the clutch pedal to feel good with threads left on the clutch rod and now the car does not move forward in gear.
however next issue i got alot of preload on the throwout bearing.
Clutch rod, z bar and fork are all GM
will shimming the flywheel help? do i have a bad pressure plate? looking for advice,already had this out once.
IF i adjust the clutch with no load on the throw out bearing the car moves forward again.....
These cars are known for there relatively short stroke in the clutch release department.
Some aftermarket clutches play better than others with this short coming.
sounds to me like you just don't have enough stroke/travel to operate the clutch you have chosen.
Back to the drawing board as they say.
Look into the clutches that DO work. Plenty of threads, information on this forum in the past on this very subject.
just because it fits a Chevy does NOT mean it will work on your Corvette.
4-Vettes is right on. I had the same problem. We have about .580 inches of available travel. If the clutch doesn't release in that amount of travel, it won't work. You can put it in a press and check that your clutch releases in this range, otherwise it won't work.
Not sure how a universal type of clutch would work out. I got one of those from Summit, but changed gears (ha) and, after some research, went with the McLeod Super Street Pro.
Wasn't all that long ago one of our resident gurus posted a fair bit of information on this topic. Including measurements taken using a press. I think it was Lars. But I could be mistaken.
What I am certain of is if you do some research you can find the answers.
You simply stated that you purchased a clutch kit from Summit. But didn't mention which one.
I personally run a RAM and I know a few others do as well and it works perfectly with the stock Corvette linkages and even pivot ball and fork.
thanks for the reply's everyone. what clutch/pressure plate/flywheel does everyone recommend, if i pull the trans again i will want to install parts that are proven to work,
I run a Centerforce II in my '79 and it works well. You also have to make sure you have exactly the right thickness flywheel, length of release bearing, and length of pivot ball. All that information is available from multiple sources, including this forum. I know because I did the research when I swapped in the 5 speed. Just don't have the details at my fingertips anymore.
The McLeod pressure plate is the one that came out on top for proper release. Lars posted a thread about it.
LUK is great and inexpensive from my experience as long as you are not over 350 HP.
If your assembled clutch is not in the middle of the threaded rod when properly adjusted you have something off. Might be the linkage pieces. I bought a whole kit from SST and they sent me 1 wrong linkage piece. Drove me crazy for a whole day. It was for a C2 Vette but I have a C3. Swapped out that rod and it all fell into place.
Can you post a few pix of your linkage? How are you adjusting the free play? What spec?
update everyone.pulled everything out, long story short i installed the clutch disc backwards, im surprised that i made this mistake even as the disc says flywheel side stamped on it......so i guess a clutch disc backwards would still disengage as long as you had the long ball stud and preloaded the throw out bearing.
i took this opportunity to replace the positive cable with a 1/0 that i made and i just installed the McLeod Super Street Pro kit that seems to be good. (clutch disc correct way)
i will hopefully get the trans back in this weekend and check back in. Thanks for everyone's replys.
ill never make this mistake again!!
Glad you got this worked out, when I read your post I figured it was a similar problem I had a few years ago on my 65. I went through a lot of work and grief over what turned out to be bad manufactured parts.
Post # 79, 83 & 87 are the meat of the conversation and fix for this problem if anyone in the future has this problem after a clutch replacement.
I got the trans back in and clutch pedal adjusted, cranked engine and everything seems to be working properly. i did leave the 1.78 ball in and once i put trans up the gap on the fork was about 1/8 from pressure plate fingers, i felt that it was too close, being that spec i read was 1/4 away. so i pulled trans out again and changed ball back to my original 1.5 long. all is well
thanks for everyones help and replys.
