Photo taken on a bench ,
this was mounted to the left of the radiator high on the panel behind the headlight structure.
The plug looks like a headlight connection but two of the wires from this,went to the positive side of the coil the other goes through the fiirewall behind the LHS head and to the ignition switch.
.Bfit
Thank you Wolfk.
did a search and you are correct , the distributor had some differences I have not seen before as well.
I’ve learned something new . Thank you .
bfit
Thanks to Wilwood for the image here. This shows where it was mounted , interested that it still connected and apparently working after all these years.
