Alternator Restoration
Old May 8, 2023 | 02:26 PM
vtech's Avatar
vtech
Default Alternator Restoration
I like to have my OEM original C3 1978 alternator restored. Would anyone know who offers this service that I can sent out restore my original numbers matching Alternator?
Popular Reply
May 9, 2023, 01:21 AM
Greg's Avatar
Greg
Just another Corvette guy
You can buy a whole rebuild kit for $35.
https://www.ebay.com/itm/19092703817...3ABFBM3su67v9h
Diode trio, rectifier, regulator, bearing, etc. Everything you need. These are very simple alternators to rebuild. Clean it and repaint it. Bingo! You're done in 45 minutes.
I just rebuilt my '78 alternator last week.
Back in and charging like crazy now.
Old May 8, 2023 | 03:55 PM
62corvette's Avatar
62corvette
There’s a guy near me who is excellent. Alstar in Waterford, WI. Jeff is the owner/restorer. Tell him Pastor Mike referred you. He is good, quick, and reasonable. Does a lot of starters /alternators for US car buffs in the UK.
Old May 8, 2023 | 06:06 PM
Geralds57's Avatar
Geralds57
2024 C1 of the Year Winner - Modified
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Ken Bruno motorsports.
Old May 8, 2023 | 06:28 PM
boat196's Avatar
boat196
I recommend Ken Bruno
Old May 8, 2023 | 07:58 PM
Eliredandblack's Avatar
Eliredandblack
Chargers auto electric, you can find their restored alternators and starters on eBay. They are honest guys and do a superlative job.
Old May 9, 2023 | 01:21 AM
Greg's Avatar
Greg
Old May 9, 2023 | 02:55 AM
hunt4cleanair's Avatar
hunt4cleanair
[QUOTE=Greg;1606605416]You can buy a whole rebuild kit for $35. Diode trio, rectifier, regulator, bearing, etc. Everything you need. These are very simple alternators to rebuild. Clean it and repaint it. Bingo! You're done in 45 minutes.
Back in and charging like crazy now. [/QUOTE]
Nice work!
So I see its a 78 yet you upgraded (?) to 70 amps? I need to do same for my 78...get parts.
Also, I see you spiffed up not only the alternator but the AIR pump as well. Did you clean before paint...or just paint. If clean, what did you use. I just pulled the pump off and want to clean it up.
Old May 9, 2023 | 02:56 AM
Tuna Joe's Avatar
Tuna Joe
Doesn’t ChevyCool rebuild alternators?
Ron just sent me a water pump and starter or my 69 and they look great.
I think he also said he tumbles the cases just like Delco Remy did.
www.chevycool.com
edit* Just checked his web site and he does do restore work.
OP, he’s also close to you in AZ
Old May 9, 2023 | 08:10 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Or just simply buy a new alternator. Remove everything and swap the cases. You now have new everything except your original numbers matching cases. Super simple and you have all new windings.
Old May 9, 2023 | 10:29 AM
vtech's Avatar
vtech
Thank you for all the feedback, appreciated.
Old May 9, 2023 | 12:44 PM
Greg's Avatar
Greg
Originally Posted by hunt4cleanair
Nice work!
Thanks. It cleaned up very easily. I just separated the case, buffed it on my wire wheel then sprayed it off with Brake Clean. Painted it with flat aluminum engine spray. Looks like brand new. And yes, I did the same with the air pump.
I've rebuilt many alternators over the years all with good success. I've never had to replace a stator or a rotor yet, they just don't seem to wear.
Old May 9, 2023 | 02:35 PM
sunflower 1972's Avatar
sunflower 1972
It's really not hard at all to rebuild your alternator. There are a bunch of how to videos.
https://www.bing.com/search?q=how+to...BA6BED8DE0B7CE
Old May 9, 2023 | 03:31 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
If you are rebuilding your own altenator....I recommend highly having the case vapor blasted. It is used a LOT in vintage motorcycle restorations......it is easy on the host metal and seals pours in aluminum leaving a like new finish that lasts......
I have had several intake manifolds done and other old bike parts......there is no better way to refurb an aluminum part IMHO......the intakes don't corrode and cleanup is easy with a light wipe of WD40 on a rag.......
Vapor Blasting | Vapor Honing — City Garage Motorcycle Shop
Jebby
Old May 9, 2023 | 03:52 PM
Hopper12's Avatar
Hopper12
'Back in the day' when I belonged to the ISCA and showed some cars, I would rebuild my own alternators because I wanted them done correctly and it was very inexpensive to do them. At shows, people asked me who did it and when I told them 'me', they asked if they could pay me to do theirs. Turned into a side job for a while and I probably did over 100 before I decided it wasn't really worth my time.
You can do it yourself no problem. As Greg said, get you a kit. Take it apart. Clean up the case. Press out the bearing (use two sockets and large C clamp if you don't have a bearing press. EZPZ). Hit the case with a light coat of clear satin (like below) as this will keep it looking like new for a loooooooong time. Get the bolts, nuts, etc. cadmium, etc. plated - not expensive (or clean them up well if they're nice). Put it back together. Take it to Advance or another parts store where you bought the kit and ask them to spin test it for you (they'll do it for free). Reinstall and enjoy your work!!! Best, Paul
Old May 9, 2023 | 04:48 PM
Mr D.'s Avatar
Mr D.
I have had good luck with using glass beads at 30 ish PSI for cast aluminum parts.
Old May 9, 2023 | 06:08 PM
interpon's Avatar
interpon
If it works i would NOT replace parts unless needed. A remanufactured ac delco alternator dropped 80 rpm compared to OEM alternator around post 95.
https://www.corvetteforum.com/forums...uestion-6.html
If you restoring I wouldn’t blast if you want to keep numbers sharp.
a brass wire wheel if needed and clean.
Old May 9, 2023 | 06:54 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Bar Keepers Friend cleanser and a stiff nylon brush to clean.
Did several alternators with this and all the 78/79 power antenna housings when I used to do them.
Old May 19, 2023 | 02:14 PM
hunt4cleanair
Well, I was inspired by this thread so I took the 78 AIR pump apart. After removing the diverter valve, pulley, steel spacer, and cast cap, I bead-blasted the pulley and the cap. The spacer I let sit for a couple of days in Evaporust...you can see the results after finishing it with a brass brush and matt finish. The pulley got painted flat black; the original finish was a gray phosphate. I may revisit that finish later. The cast cap got semi-gloss. I cleaned the aluminum case with the Bar Keepers but it really did not remove the aging or staining.
More interesting is the pump guts. I used brake cleaner to clean the bearing that is in a seat just inside the case. I also cleaned a rod that extends from the cast cap, then greased both the rod and the bearing. The rod fits down into a series of baffles, or fins that rotate around the casing, thus creating the pressure that pushes O2 into the diverter valve on its way through the emission hoses and into the manifold pipes. A fun project and only took a couple of weeks tinkering with this, that and the other.
Thanks to forum members here who contributed to this inspiration!
Old May 19, 2023 | 03:22 PM
ctmccloskey's Avatar
ctmccloskey
I rebuilt my own alternator and used Baking Soda for the blasting the case and pulley. It came out beautifully and then was rebuilt and put in a bag with the air pulled out. Storing these parts in a vacuum keeps them looking great. I then installed a aftermarket higher amperage alternator which is on the C3 to this day.
The distributor and parts for the transistorized Ignition were cleaned and vacuum bagged as well. The idea is I want to keep the original parts for my engine but am not using them on my L88 replica engine. Down the road the next owner might want to go back to original and this makes their life easier.
Aluminum Cleaner used for welding aluminum works great as well. It removes all the corrosion down to the bare aluminum. I find it to be the easiest way to clean aluminum components.
To Alternator Restoration
