I am running a 9" torque converter (2800 stall) so I figured I need a deeper pan for capacity and cooling
Been running this on my '74 since 2000, no probem but the drivers side exhaust pipe is very close
I am running a 9" tourgue converter (2800 stall) so I figured I need a deeper pan for capacity and cooling
No, The dipstick is measuring the top level of fluid (how low below the top edge the pan) not the depth of the fluid
I think he's refering to the pickup tube for the filter. usually when you put a deeper pan on there is a extended pickup tube to move the filter down to the same height above the bottom of the pan. i have the TCI deep pan on my car and you do lose a little ground clearance but have not had any problems.
