1980 Corvette ATF location help.
Old May 31, 2023 | 06:36 AM
doning's Avatar
doning
Default 1980 Corvette ATF location help.
Hello. I want to change the fluid and filter in my TH350 on my 1980 Corvette. It has 60,500 miles on it and I am not sure if the previous owner changed the filter. Through internet research, I take it you can no longer buy Dexron II ATF. So, what do I use? Would it be Dexron III? I do not want to use synthetic ATF. Any idea where I can purchase Dexron II? Advance Auto, Autozone, Amazon, eBay are the places I looked. Thank you.
Old May 31, 2023 | 09:32 AM
BillDurant's Avatar
BillDurant
you should be be the C3 section
Old May 31, 2023 | 10:29 AM
SH-60B's Avatar
SH-60B
Use Dex III it is compatible
Old May 31, 2023 | 11:34 AM
doning's Avatar
doning
Opps! That's what happens when you post at 6:30 in the morning!
Old May 31, 2023 | 11:40 AM
doning's Avatar
doning
Thanks SH-60B. Will there be any difference in the shift feel?
Old Jun 1, 2023 | 08:53 AM
SH-60B's Avatar
SH-60B
No, just a feeling of the warm fuzzies that you get when you do some routine maintenance on your sports car. You might have an issue if you are experiencing slow or soft shifts.
To 1980 Corvette ATF location help.
