Transistor ignition replacement parts
Old Jun 1, 2023 | 09:18 PM
prestodixo's Avatar
prestodixo
Default Transistor ignition replacement parts
I have these solid state cross reference books from the 70’s and they have the delco numbers for the 1969 ti board. I plan on purchasing them to repair my board. I’ve tested everything except the pulse signal coming from the pickup coil in the distributor, What voltage should I see when cranking the engine? I am feeding it 12 volts on the gray wire. There is 12 volts on the pink wire when not cranking and 9 volts when cranking. I have the amplifier out and on the bench.
thanks in advance
mike
Old Jun 2, 2023 | 12:30 AM
Peterbuilt's Avatar
Peterbuilt
Default Does this help?
http://www.tispecialty.com/print/9.pdf
Old Jun 2, 2023 | 09:42 PM
prestodixo's Avatar
prestodixo
Thanks for the reply, unfortunately that article is for a points distributor only and does not discuss TI models.
Mike
Old Jun 2, 2023 | 11:18 PM
Peterbuilt's Avatar
Peterbuilt
http://tispecialty.com/articles/66-71diagram.htm
If that doesn't help go to his home page or Google TI in a1969 Corvette.
Old Jun 2, 2023 | 11:40 PM
robertea's Avatar
robertea
You can try this one page document "66-71 TI Ignition" to see if it helps. I downloaded it somewhere, but have never used it.
The drawing is something that I made a few years ago when I couldn't find anything decent on the internet.
Old Jun 3, 2023 | 08:32 AM
stingr69's Avatar
stingr69
If I were you I would try this bench test - You can try hooking up an ANALOG multimeter across the wires from the pickup and then rotate the shaft. I had to do that for my magnetic pickup points distributor conversion. I was unsure about the polarity of my 2 Chrysler pickup wires and the engine was doing crazy things with the timing just off-idle. Once I got the wave form right, it works like a charm. The meter needle will pulse "up and then down" as the reluctor passes the pickup points if your pickup is working. Rotate distributor shaft in opposite direction and the wave form will be "down then up" form, but in your case you already know which way to wire it, so no concern for you.
Digital readout meter is not good for this test.
To Transistor ignition replacement parts
