77 Corvette Restoration
Old Jun 7, 2023 | 08:44 AM
kumishah's Avatar
kumishah
Default 77 Corvette Restoration
Hey all, i'm new here and just recently purchased a 77' corvette coupe w/ Auto Transmission through an auction. Its in pretty bad shape, a complete gut job, however the frame and birdcage seem to be solid and the body itself is quite nice. I've started to gut the interior and figured i'd start off with getting the vehicle water tight since there are no windows for the doors. While doing that I see that pretty much all the electrical wiring needs to be replaced (along with just about everything else). I was going to purchase a wiring harness kit for the entire vehicle, but wanted to first find out what is the difference between 1st Design and 2nd Design for the wire harness? Thank you in advance.
- Kunal
Old Jun 7, 2023 | 11:04 AM
SEVNT6's Avatar
SEVNT6
If I remember right it involves the alarm.
GM moved the switch from the front fender & incorporated it into the driver side door lock during '77.
The alarm horn was also moved...
Old Jun 7, 2023 | 11:23 AM
kumishah's Avatar
kumishah
Awesome, thanks for that info SEVNT6! Appreciate the insight.
Old Jun 7, 2023 | 01:37 PM
bmotojoe's Avatar
bmotojoe
To be more specific,,,everything lol...
1st design A/C harness
1st design Main Dash Manual Trans
1st design Main Dash Auto Trans
1st design Engine Harness Manual Trans
1st design Engine Harness Auto Trans
1st design Forward Lamp Harness
1st design Front Parking/Turn Signal extension Harness
1st design Non A/C Heater Harness
1st design Neutral Safety Switch extension Manual Trans
1st design Power Window Harness
1st design Rear Body Harness
1st design Starter Solenoid extension Harness
When the 2nd design change happened VIN 27373 to 49213 they built 1 harness for each area for both auto and manual transmissions, except the neutral safety switch harness...
Old Jun 7, 2023 | 01:50 PM
kumishah's Avatar
kumishah
I gotcha, so basically it would work for both auto and manual. makes sense. Thanks for that.
Old Jun 7, 2023 | 02:30 PM
bmotojoe's Avatar
bmotojoe
Depending on what harnesses you are talking about...
1st design harnesses are 1st design harnesses...
To 77 Corvette Restoration
