oil filter
Old Jun 11, 2023 | 08:55 AM
signify's Avatar
signify
Default oil filter
can i spin my oil filter off and only have oil in filter and not have en gine drain completely empty?
Old Jun 11, 2023 | 10:41 AM
ctmccloskey's Avatar
ctmccloskey
Yes, you can remove the filter and replace it by itself without loosing the rest of the oil in the oil pan. I am not sure why you would want to do something like this but it is possible. Just be sure to replace the amount of oil that was in the filter after installing the new one.
Old Jun 11, 2023 | 10:59 AM
signify's Avatar
signify
Old Jun 11, 2023 | 01:02 PM
LowSporty's Avatar
LowSporty
Sig, there's no reason to do that! If the motor needs an oil change, don't "half-***" do it right, change the oil and filter, shoot the grease fittings if they need it, basic maintenance. "Wham Bam, Thank-You Maam'' Your Done, Regards from a 22 yr. heavy equipment mechanic, LowSporty
Old Jun 11, 2023 | 01:18 PM
signify's Avatar
signify
thanks saw metal chips in old filter so checking again for repeat
Old Jun 11, 2023 | 01:22 PM
LowSporty's Avatar
LowSporty
I see, now I understand. Yes, you can do that. Regards, LowSporty
Old Jun 12, 2023 | 07:41 AM
cottoneg's Avatar
cottoneg
Send the oil out to Blackstone for analysis. The report will be much more enlightening.
Old Jun 12, 2023 | 11:57 AM
RetroGuy's Avatar
RetroGuy
You may also want to install a magnetic oil pan drain plug.
To oil filter
