power steering squeak
Old Jun 14, 2023 | 10:06 PM
delandjohn's Avatar
delandjohn
Default power steering squeak
Have '72 454 with power steering. Whenever I turn steering wheel to right there is a loud squeak. Belts have been replaced and adjusted with dressing applied so probably not a belt. Any idea what it might be?????
Old Jun 14, 2023 | 10:08 PM
RetroGuy's Avatar
RetroGuy
Obnoxiously obvious question, but have you checked the power steering fluid reservoir???
Old Jun 14, 2023 | 10:26 PM
delandjohn's Avatar
delandjohn
Yes, first thing I did. Full. Also failed to mention there are no leaks.
Old Jun 14, 2023 | 10:29 PM
Mooser's Avatar
Mooser
Have a look and see if this helps at all
https://www.corvetteforum.com/forums...ing-right.html
M
Old Jun 14, 2023 | 11:35 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Kinda curious for more descriptive info: Is it like a high-pitched belt squeal? A creaking squeak?
Read through the other thread Mooser posted and also check the attachment points and lube points for every linkage component. Has anything been worked on recently?
To power steering squeak
