1969 Corvette Electrical issue?
Old Jun 14, 2023 | 10:52 PM
Jmweave's Avatar
Jmweave
3rd Gear
Default 1969 Corvette Electrical issue?
I went to start my Corvette After a long winter in my garage with my battery. Tender on. My battery didn't hold a charge. So I replaced my battery now. My Corvette doesn't start. At first the don't light was on. And when I turn the key over it Clicked once and didn't work. I Pulled off the starter and checked it , works with. Now I have no power anywhere.The battery says 12.57 V. I checked the positive on the solar and it only has 4.5 V. Any ideas?
Old Jun 15, 2023 | 09:49 AM
Tampa Jerry's Avatar
Tampa Jerry
Welcome to the forum. I would start with the easy stuff, thoroughly clean all the battery connections both positive and negative to the starter and frame. If your car has a neutral safety switch, troubleshoot it to see if it works or is adjusted correctly. The car has fusible links which may be fried. At the very least, get a test light or a multimeter and start checking out your wiring. Good luck. Jerry
