1979 corvette ignition cylinder
Old Jun 23, 2023 | 07:37 PM
Drwcifer's Avatar
Drwcifer
Default 1979 corvette ignition cylinder
Hi guys. Ive lost the keys to my baby. Its béen several years since ive replaced one. I know it has to be in the run position when installing the new one. Simple. They come with keys lol. My question is do you have to have a key in run to remove it? If so, would it be better to drop the column and unhook it from the ignition module or just break it. I have the pull down tab you have to press to get key out and fear I may damage it if I try and break it.
All input would be welcome
Thanks gang
Old Jun 23, 2023 | 09:10 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
The cylinder will come out with it in the lock position.
once you remove the lock ring to get into the column all will be good. Remove the retaining screw after you get the signal switch out of the way. And out it will come. Insert a large screwdriver in it's place and turn the mechanism to the on position. You will see the little shaft for the steering lock drop down and you'll be ready to install a new barrel.
Old Jun 23, 2023 | 09:11 PM
Drwcifer's Avatar
Drwcifer
Thanks. I appreciate it
Old Jun 23, 2023 | 09:34 PM
4-vettes's Avatar
4-vettes
The service manual is pretty darned good at explaining the process of ign. barrel replacement.
might want to give it a look over before you start. And make certain you have that spring compressor tool if you have a tilt/teli column.
Old Jun 23, 2023 | 09:36 PM
Drwcifer's Avatar
Drwcifer
I have the tool and the manual but its old and my eyes are old.the.manual that is
Old Jun 23, 2023 | 10:31 PM
4-vettes's Avatar
4-vettes
Welcome to the club. Both my manual and my eyes are old as well.
Old Jun 24, 2023 | 08:00 AM
Drwcifer's Avatar
Drwcifer
Out
of curiosity. Does your shop manual have blurry black and white photos? Heres a pic of just one of the pages in mine
Old Jun 24, 2023 | 08:04 AM
4-vettes's Avatar
4-vettes
I have the genuine GM passenger car manual. It has a lot of black and white photos. But not blurry. Actually quite clear.
Old Jun 24, 2023 | 08:09 AM
Drwcifer's Avatar
Drwcifer
This is what I have.
Old Jun 24, 2023 | 08:29 AM
Bikespace's Avatar
Bikespace
That looks like a well-worn reprint. The originals had color wiring diagrams, much better contrast in the photos, and a cover with texture.
Here's @interpon's comparison:
https://www.corvetteforum.com/forums...omparison.html
Normally, Jim Shea's site would also have the information you need.
http://jimshea.corvettefaq.com/
But the link doesn't work for me right now. YMMV.
To 1979 corvette ignition cylinder
