Engine Lift Tabs?
Old Jun 26, 2023 | 01:30 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Default Engine Lift Tabs?
My '71 350/270 coupe had engine lift tabs on it (2 bolts on drivers front corrner of intake & passenger side upper bell housing bolt) when I took everything apart but, now in the reassembly phase, I see nothing about them in the AIM. Did C3s of that time come from the factory with the tabs or were mine added sometime later?
The tabs themselves are 3/16" thick - do I need to use longer bolts with them and, if so, would 1/2" or even 1/4", be too long?
Thanks for any insight...
Paul
Old Jun 26, 2023 | 02:27 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I suspect the lift brackets were part of the assembled engine from Flint -- therefore not installed by St. Louis, so not called out in the assembly manual. As far as I know, what you describe sounds like they are proper but a pic would help.
Old Jun 26, 2023 | 03:24 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
1 front drivers side 1 rear pass side.
stock bots
diff lift brackets front and back
Old Jun 26, 2023 | 03:34 AM
Eliredandblack's Avatar
Eliredandblack
Best illustrations can be seen in some of the Corvette vendor catalogs. If you need pictures let me know.
Old Jun 26, 2023 | 04:10 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
My 77 definitely came factory with these lift lugs. Although I removed them for cosmetic reasons. I still have them and they may come in handy if ever the need to pull the engine arises. But of course it's a small block Chevy so it never needs to be repaired.
Old Jun 26, 2023 | 04:46 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Thanks guys - I thought that might be the case. I do still have the brackets (called them tabs because I brain farted and couldn't get the right terminology to save my life - doh )
As for reinstalling them, CALWLDLFE said stock bolts so I assume that means the ones going thru the brackets don't need to be any longer than the others mounting the intake manifold and the bell housing - correct?
Old Jun 26, 2023 | 05:13 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
the beefier one goes pass back
Old Jun 26, 2023 | 10:27 PM
Eliredandblack
The lift brackets were gone from my 73 SB. I ordered the brackets from Paragon and they showed longer bolts (than the ones for intake manifold bolts). Don’t know if it matters, but since I was ordering a bunch of parts, I purchased the longer ones.
Old Jun 26, 2023 | 10:34 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
when you take the original bolts out and line them up, I bet there are
differences.
gm put those bolts in, but you OP are convinced you need longer bolts so buy em.
Old Jun 27, 2023 | 02:16 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
differences.
That's the problem. I had a different intake manifold put on when the engine was rebuilt, so new bolts were used, not the original bolts.
I don't know why you think I'm convinced I need longer bolts. I just want to find out if GM originally used longer bolts, or if bolts the same length as the rest of the intake manifold are sufficient in their eyes as well as the thoughts of others on the forum.
If the intake bolts my builder used won't have enough threads into the block to properly secure that front corner of the intake after passing through the bracket, I'd want to use longer bolts to prevent any leaks. But then again, not so long that they'd bottom out before achieving the proper torque.
Old Jun 27, 2023 | 02:37 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
so you have all this info and want to talk stock bolts?
yes gm had different length and some bolts had shoulders where threads did not go to the heads.
since you nnow dislosed a third party got rid of the bolts then you should know.
geez
Old Jun 27, 2023 | 06:27 AM
4-vettes's Avatar
4-vettes
Been a long while since I removed lifting lugs. But I do remember that I had to fit somewhat shorter bolts in the intake manifold when I removed the lift lug as the lug is about a quarter inch thick. I had to use 2 replacement bolts that were 1/4 inch shorter.
later, down the line I replaced the intake manifold and installed ARP bolts. And those of course were all of the same length as they didn't accommodate the lift lug.
Old Jun 27, 2023 | 11:42 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Thanks to those that answered this newbie's questions without any snarky comments!
Old Jun 28, 2023 | 01:09 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
To Engine Lift Tabs?
