manual vacuum overide pulldown switch question
Old Jun 27, 2023 | 04:33 PM
jbhammer's Avatar
jbhammer
Default manual vacuum overide pulldown switch question
Trying to sort out vacuum issues for my wiper door and headlight doors. I replaced both pulldown overide switches. The two pair of lines (one pair each switch) have a rubber 90 degree boot where the lines plug into the boot and the other side presses into the two male tabs on the back of the switch. Unfortunately, these boots are leaking. I could not find a source for them from the major suppliers. Any source for that? or would you recommend just installing the bare ends of the hoses directly onto the nipples of the switch. Thank you!
Old Jun 27, 2023 | 04:58 PM
BLUE1972's Avatar
BLUE1972
I used a piece of silicone Tubig on a friends car. ( like for a model airplane- hobby store)
Check Flee Bay, for parts
1968L-82 Corvette Vacuum Override Switch Junction Blocks pair used | eBay
Old Jun 27, 2023 | 10:32 PM
bobby70's Avatar
bobby70
Why. dont you just put the hose right to the valve
Old Jun 28, 2023 | 12:07 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I just hadthe same problem...I wasn't concerned aboutnoriginality on mybasketcase project so I connected the vac hoses to the switch nipples/tight fit.
I also added 1 foot to each hose to make it easier to remove the gauge panel when necessary (function over originality in my case)
Old Jun 29, 2023 | 09:15 AM
jbhammer's Avatar
jbhammer
Thanks everyone for their input. Didn't want to chance buying used replacements, they may leak as well. Since this won't be a show car, I decided to attach the hoses directly to the pull down switch. Good tight fit as doorgunner described. Problem solved!! Wiper door and headlights now work great.
Old Jun 29, 2023 | 10:13 PM
bobby70's Avatar
bobby70
WHY. dont. you just put the. hose right to the valve
To manual vacuum overide pulldown switch question
