squeak problem
Old Jun 30, 2023 | 02:59 PM
delandjohn's Avatar
delandjohn
Default squeak problem
Have 1972 convertible with factory original removable hardtop. Rubber seals all around between top and car squeak like crazy. Front, back, and around both windows. Seals are about 2 yrs old. Very annoying. Tried spray silicone. No improvement. Has anyone else had this issue? Any suggestions??????????????????? Thanks.
Old Jun 30, 2023 | 07:19 PM
kanvasman's Avatar
kanvasman
I have a bad squeak on my c6 right behind my wife’s head! Tried all kinds of silicone and weatherstripping treatment stuff. You can actually hear the noise when you drag a rag across it with the silicone. A friend suggested vasoline. That is what I am going to try when I get home from this trip.
Old Jun 30, 2023 | 08:27 PM
delandjohn's Avatar
delandjohn
Let me know how it works out.
Old Jun 30, 2023 | 09:00 PM
REELAV8R's Avatar
REELAV8R
Could try this, it's a grease vs a spray.
https://shop.advanceautoparts.com/p/...g-4/10607939-P
Old Jul 1, 2023 | 12:44 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
Curious how long you have owned the car. I have never been in a c3 that did not rattle and squeak.
I guess you could try to tighten the front pins up a bit but I do not think it a rubber issue. Good luck.
Old Jul 1, 2023 | 01:09 PM
delandjohn's Avatar
delandjohn
Have owned it a couple of years. This is very distinct from normal body squeaks. Only happens when hardtop is on and not with soft top. Can actually hear exactly where the squeaks are coming from. For example, if I roll the windows down an inch then the squeaks emanating from window are gone.
Old Jul 1, 2023 | 01:25 PM
sunflower 1972's Avatar
sunflower 1972
3M Squeek reduction tape:https://www.3m.com/3M/en_US/p/d/v000368418/
Old Jul 1, 2023 | 02:22 PM
delandjohn's Avatar
delandjohn
Thanks for the info. Did not know such a thing existed. Just ordered a roll from Amazon.
Old Jul 1, 2023 | 04:23 PM
sunflower 1972
I kept a roll of it in my Parts Department. You never heard of it it because 3M never marketed it to the retail side. It is one of many 3M products that are "For Professional Use Only."
To squeak problem
