Spare tire lock
Old Jul 13, 2023 | 02:57 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Default Spare tire lock
OK, so this has been bouncing around my storage tray since I bought my car 30 some years ago.
It's the original factory spare tire lock.
The real issue is, shortly after I purchased the car I replaced both door locks as one was no good. So I don't have a key that fits it all these years later.
Can these be re-keyed? Is this even worth hanging on to? Or is it just an interesting paper weight?
Old Jul 13, 2023 | 08:35 AM
KS69Coupe's Avatar
KS69Coupe
Yes, it can be re-keyed by a good locksmith. Original spare tire locks are hard to come by so I would get it re-keyed and put it on your car. Your round accessory key should be able to open your doors, open the center rear storage compartment, and open the spare tire lock all with the same key.
Old Jul 13, 2023 | 11:22 AM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
This is correct… The oval head key operates the storage compartment lock, spare tire lock, and (after mid 1970) the alarm switch.
The spare tire lock is (along with the storage lock) the easiest to re-key, so if you don’t have the oval head key (or if it doesn’t match the storage lock), it is very easy to address the issue.
Regards,
Stan Falenski
Old Jul 13, 2023 | 07:33 PM
4-vettes's Avatar
4-vettes
I've always had a separate key for my alarm switch. And recently I replaced the alarm switch as the original froze up. And in all my years never once tryed to lock that center storage compartment. But perhaps I could get this spare tire lock keyed to match my alarm key. I'll have to check into it. Thanks for the advice.
Old Jul 14, 2023 | 01:55 AM
Eliredandblack's Avatar
Eliredandblack
The original locks had a rubber cover/housing to keep dirt out, they are readily available and the cost is very reasonable.
To Spare tire lock
