Dubious '79 C3
PS: I'm willing to put some work into it, the engine bay doesn't look to be the cleanest
the Vin number clearly states which engine the car was born with. And if the engine stamp pad matches then it is the original block. An all factory stock 79 didn't have enough power to get out of it's own way. Be happy someone warmed it up.
Your correct the engine compartment isn't perfect. But I've seen a lot worse. It's a 79. Originality just shouldn't be all that important.
It's obvious from the pictures that the engine has had some modifications. The intake is an aftermarket from Edelbrock, the carb appears to be an Edelbrock too. The air cleaner's a replacement, the stock cooling fan is gone, as is the fan shroud, apparently replaced by electric radiator mounted fans. The car originally had air conditioning, but the compressor and other associated parts have been removed. The valve covers are what came on L-82's, but considering the other changes, they may have been changed too.
On the right (passenger side) front of the block, below the fuel filter will be a machined pad. On that pad will be two series on letters and numbers. One set will be a portion of the VIN number (if it's original it will match that car, if not it will match the one it came out of) and the second set will identify the engine and when and where it was made. If you can get a picture of that pad, or post what's stamped on it here, one of us will be able to decode it and tell you more about what engine it is.
The emission label on the left top of the firewall, above the brake master cylinder, will have a 2 letter code on it. If that code is CJ, then the car originally came with an L-82, if it's an X6, CR or CM, then the original engine was an L-48, but the only way to identify what engine is actually in the car, is with the information from the pad on the front of the block.
Some type PCV system on the valve covers with passenger hose going, who knows where. Drivers side appears to take a shortcut to the carb under the master cyl?
Another small hose zip-tied to the upper rad hose.
Some type of shut-off valve on the lower rad hose.
Front shocks dust covers missing.
Drivers side plug wires taped together coming off the dizzy. That's a big no-no especially for cyl # 5 & # 7
Heater hoses missing or rerouted somewhere?
Now the L-82 when done up nicely is a damn good engine....a hidden gem and the best factory small block to modify...(the 71-72' LT-1 short block was identical in every way)......and on an engine dyno with long tube headers and a good timing curve will make 320hp on an engine dyno (not how GM rated these engines).......
Jebby
hard to see is the power steering pump missing too?
if not crashed and limited rust in critical areas (looks OK from top!) you can always fix it up!
here is a my 79 L82.. get the vin # and the engine # as mentioned..
mine's a lowly 79 and important/ fun for me originality
Then again, I'll go have a look in the near future and maybe make an update on the spot, thanks again all for the help! A couple more pictures to give an idea of what the body condition is
These cars are quite rare in Europe and very hard to work on because hardly anybody is familiar with them
A Canadian car will be cheaper to ship and to buy do to our poor dollar exchange V.S. US Dollar and the Pound or Euro.
You're right about the interior. When new if it had a red interior it would have been all red (seats, carpet, door panels, steering wheel, console, headliners, etc) and if it had been black it would have been all black. Also, the door panels are custom, that's not the pattern/design that would have been on original door panels.
It's an attractive car and appears to have some good points, but it is priced pretty high compared to what it would go for in the States, but then it's not here, which does make a difference.
Good luck with your search, whether you end up with this car, or another.
