NCRS Question - Exhaust
I know Volunteer and I think Eckler's, were selling systems made by East Tennessee Vette, which are very nice systems that fit well, and are priced reasonably, but they're not 100% NCRS correct.
You CAN get carbon steel by special order. I believe that you have to prepay and there are no returns, but you can get it. I have an LT-1 system in carbon steel that I’ve had for 8+ years. It has been in heated/air conditioned storage and is as rust free as the day I bought it. It will last!
The down pipes for the 1968-1972 cars are very accurate. The LT-1 pipes are dead on and in speaking with Eric Gardner, it sounds as if both smooth and wrinkled big block pipes are being offered (ask the team leader what he wants to see before ordering). I would imagine that the 2” pipes for your L-46 are good as well.
The rear pipes for the 1968, 1970-1972 big blocks and 1970-1972 LT-1s are way off. The pipes should be flattened continuously over most of the length of the pipe (through the bends) and they aren’t. Spoke to Eric (and his dad while he was still with us) and he didn’t seem to be inclined to make any changes. The 2” systems should be OK as the weren’t flattened.
The mufflers are off as well but they can be made to work. The crimps are off, but those can be fixed, the original mufflers had an embossed “W” on the case (driver side facing up, passenger side facing down) which can be added, and the bead around both ends of the muffler are more round on the originals.
You’ll need to butt weld the rear pipe to the muffler as original, but that was never a problem for me as it allows the exhaust to be fitted perfectly to the car.
Gardner does not wholesale their exhaust systems… They are the one and only producer and seller.
They don’t sell pieces of systems. You buy the whole set (pipes and mufflers) and that’s it.
Unless the quality of NCRS judging has declined dramatically since I stepped down as team leader, neither Gardner nor Corvette Central systems will pass without deductions (as delivered).
Regards,
Stan Falenski
Regards,
Stan Falenski
Thank you guys for all of your responses. I am curious about the carbon steel option from Gardner. I would think that carbon steel would get fewer NCRS point deductions under CDCIF than aluminized exhaust? Not sure about that, just my intuition. I am certain my brand new exhaust system will not get 100% and I am okay with that. Would just like to get as many points as I can get and be as close to OEM as I can get.
I am good with buying the entire system because I need everything from the exhaust manifold and down exhaust collector all the way to the back, including clamps and hangers. I'm okay with welding, I don't have a welder but I know lots of resources nearby who can do that once I have the fit and alignments and spacing (clearances) where they should be.
Corvette Central offers welded muffler aluminized complete exhaust systems. Anyone know if CC offers carbon steel as an option? Again, my assumption being carbon steel would be closer to OEM than aluminized and that aluminized would get fewer point deductions under CDCIF that say stainless steel (which I am not even considering).
Appreciate y'all. Thanks in advance for sharing your knowledge, expertise and suggestions.
Kevin
Did a little more research on carbon steel and I think I have determined, at least in my mind, that carbon steel would result in lower points under CDCIF than aluminized. Looks like aluminized exhaust is the way to go. I'll add exhaust to the list of things that I know are not 100% NCRS correct on the car.
Thanks Stan, Grant, Paul and others for your assistance.
