Hi does anyone had the diagram for the rear lights and some other pointers, the rear lights are all jumbled somehow the indicator lights no longer blink and the rear lights also come on at the same time when the indicators are on.
You can find wiring diagrams here, though you should pick up the shop manual and assembly instruction manual for your year of car. It's also helpful to state which year you have.
Weird behavior from LEDs is to be expected. Here is everything I learned when switching every single bulb to LEDs in my 80, which work properly with some added bits, if that's helpful to you.
