Their actually urethane same as the front and rear bumper covers, these spoilers started in 78 with the Indy package.whether they were installed at the factory or the dealership, they are OEM
code D80
Reason: Want to add
you would typically remove the prior layer of paint carefully ..
check the system you are using but typically primers need flex additive and the base coat and clearcoat hardener for maximum flexibility..
here is the spoiler i did recently https://www.corvetteforum.com/forums...on-advice.html
