Door jamb issue
Old Jul 27, 2023 | 10:59 PM
ceejay1101's Avatar
ceejay1101
4th Gear
Default Door jamb issue
Hello! Just bought my first corvette and I have a fiberglass issue in the jamb area. The fiberglass lip where the interior plastic hooks to, is completely snapped off. Any fixes for this?
Old Jul 27, 2023 | 11:04 PM
Eliredandblack's Avatar
Eliredandblack
Pictures will be of great help in getting quality repair ideas. Go to advance the. You can use your iPad or phone to take some photos.
Old Jul 27, 2023 | 11:16 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
not until he has more posts.
I don't remember how many he'll need.
Old Jul 27, 2023 | 11:18 PM
ceejay1101's Avatar
ceejay1101
4th Gear
just added a pic. Hope this helps.
Old Jul 27, 2023 | 11:30 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
wow.
2 posts and pics?
good
looks bad, learn how to lay glass
Old Jul 28, 2023 | 06:57 AM
Eliredandblack
My two cents, maybe very thin sheet metal to be used as a mold with fiberglass Matt and resin. Once you have the mold / sheet metal formed correctly, then make the needed piece. You will need to apply a release agent to the sheet metal so the fiberglass will release. Finally epoxy the new piece to the jamb.
A second repair method would be to make small sheet metal “Tabs” that could be held in place (mounted to good fiberglass) with epoxy like JB Weld. You would need a “Tab” for each one of the trim pieces screws. The “tabs” would be covered by the trim piece.
Good Luck.
Old Jul 28, 2023 | 07:11 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
The one photo just doesn't make it clear to me the proper repair. As much as I'd like to be helpful, I wish I could see around that corner.
Old Jul 30, 2023 | 12:54 PM
OMF's Avatar
OMF
Ask and you shall receive.......
But really...I was working on replacing my carpet, saw this thread and shot a few pics to help the OP figure out what it's supposed to look like.
You could probably make an aluminum piece and repair this, but IMO it would always look like a hack repair. I would make a form with the proper offset and screw it to the birdcage and do a fibreglass repair. If you put a release agent on the form it should come off easily after the glass has hardened. grind it down and bodywork it as required.
Old Jul 30, 2023 | 07:32 PM
bazza77's Avatar
bazza77
Find someone with a wrecked corvette C3 , that part is all the same 68 -82 . Cut that piece out then find a guy who's good with glassing to splice it in for you . Its a tough repair for a beginner ,especially when you don't have all the piece to start with .
If you get it wrong the door will crack it quick smart after a few closings ,been there .
To Door jamb issue
