How do you Cool a Hot Corvette ?
Old Aug 15, 2023 | 01:51 PM
maddog11's Avatar
maddog11
Default How do you Cool a Hot Corvette ?
I'm original owner of a 1978 Silver Anniversary C3. The ventilation system blows hot air when Vent is selected with the "coolest" setting. If I select "hot" then the ventilation system blows even hotter air.
I recently had the air conditioning system converted to R134a. The air conditioning initially blew cold air when I'd alternate between AC and Vent, but now all I get is warm/hot air with either selected.
Not sure is these are related. Any help would be appreciated?
Old Aug 15, 2023 | 03:20 PM
ChiliPepperGarage's Avatar
ChiliPepperGarage
How to cool a hot Corvette?
Here you go:
I hated this movie when it came out because of this scene.
Old Aug 15, 2023 | 03:22 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Cut the brown wire at the heater box for the low speed......motor stops spinning on low. This was a common thing to do back then......you could not shut the blower motor off.
Jebby
Old Aug 15, 2023 | 05:27 PM
HeadsU.P.'s Avatar
HeadsU.P.
I bet a chili dog, fries & shake the Heater Core is still blasting you.
Some engineer genius thought that the heater shut-off switch should run off vacuum, no less. Just what C3s need is more vacuum accessories right?
You will need purchase a heater hose shut off valve. Install in in place of the POS that's in there now. The valve is available at NAPA for around $30.
They come in 5/8 or 3/4 inch hose bib. Simple threaded screw style valve, open in the fall, close in the spring. You can hide in down by the firewall.
To How do you Cool a Hot Corvette ?
