1977 seat angle spacers
Old Aug 22, 2023 | 09:26 AM
khoeysr's Avatar
khoeysr
Corvette fan
Default 1977 seat angle spacers
After a few days of uncomfortable driving, I am asking about the seat spacers that are mentioned in the owners manual to adjust the seat angle. They are available from the dealer, IF it is 1977.
Anybody use these and know where to get them?
Old Aug 22, 2023 | 10:30 AM
Mark G's Avatar
Mark G
Are you trying to tilt it forward more (or back)? Or raise up? Does the seat back seem 'tight' ...as in no worn parts?
These might not be factory, but...
https://www.ebay.com/itm/C3-Corvette...6919170?_ul=IN
Seat Back Shim Kit:
https://www.southerncarparts.com/c3-...-shim-kit.html
Repair kit
https://www.ebay.com/itm/38305160368...hantid=6504474
Old Aug 22, 2023 | 10:50 AM
khoeysr's Avatar
khoeysr
Corvette fan
Seat Back Shim Kit:
Repair kit
Forward, more upright. I will check this out. Thanks.
Old Aug 22, 2023 | 12:28 PM
Mooser's Avatar
Mooser
You can unthread the stops on the seat bottom to adjust the angle more straight and then measure the gap between the stop and the seat to figure out the spacers needed.. they a just larger washers really and you'll need to space the center seat lock strap the same.
Be careful when sitting on the seat with just the stop unscrewed and no spacer, if you press back to hard the force is put onto the nut that is spot welded under the seat frame rather than to top of the frame and can be torn off
M
Old Aug 22, 2023 | 02:12 PM
khoeysr's Avatar
khoeysr
Corvette fan
How about adding 1 pair of washers , sit and see, then maybe add another?
Old Aug 22, 2023 | 03:12 PM
Mooser's Avatar
Mooser
Sure, just a tiny pain to take them all the way out, add a washer, all the way in, etc. but there's no risk of breaking the nuts loose. adjusting without the spacer is fine as long as you're not really pressing hard against the rear or thumping on it getting in/out.
Don't worry about the center lock bar until you get the angle set the way you want, it just won't lock the seat back in place
M
To 1977 seat angle spacers
