Rear tray cover
Old Aug 29, 2023 | 08:27 PM
Golferdad's Avatar
Golferdad
Default Rear tray cover
Remodeling interior and the molding around back glass and the rear tray cover I guess you call it,is a black,mine appears to be fine dull looking of course,but we’re these pieces painted like flat black,and can the cover be removed with a few screws,or is it attached to the pull out cover.
This is looking from outside threw glass
Old Aug 30, 2023 | 03:26 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Remove the screws and the corner pieces.
Also remove one side of the halo panel, will give you room to swing the shelf out.
You may have it stick a bit due to sealant from the rear window.
I used Zinzeer stripfast paint remover to get the sticky finish off. Don't sand, don't want to mess up the texture.
Painted mine with flat black Rustoleum with a spray gun.
Pretty sure you could also use flat black Rustoleum with a brush, just knock down any brush marks by stippling the finish with your brush. The flat levels out nicely.
Either way will be better than spray can.
Did this procedure on 4 cars, 2 79s and 2 78's.
Once I started and saw how good things went couldn't stop!
