Another "What is this?" question
What is the purpose of the black-headed bolt between the timing cover and the fuel pump to carb hard line? Should it be there?
Bet you'd never guess that this is my first resto/rebuild...
Anyone not so knowlegable (like me) about such things may find these links of some use explaining how that works. All you ol' gear heads and mechanics need not waste your time looking at them...
http://67-72chevytrucks.com/vboard/s...d.php?t=138417
It may not matter except for a few degrees of timing uncertainty if you aren't lined up properly. But it also indicates mis-matched parts, which seemed to be the theme of this thread.
Good sharp eye and thanks for bringing the tab up!
Going back to check some old photos of the original engine, I see that the timing cover must have been changed during the rebuild (had a different stamping pattern on the front than it does now) and that the damper now appears smaller than it used to (further from the water pump).
I'm guessing that the car ('71 coupe 350/270) originally had an 8" damper as the timing tab in the old pics was much closer than it is now. The builder must have put a new cover on when replacing the timimg chain & gears along with a 6.75" damper. Perhaps he reused the tab designed for the larger damper. At least that's my guess.
I'll check my paperwork and/or ask the builder. Unfortunately, that was 3 years ago so he might not even know unless he keeps good records.
I imagine I can get a timing tab for the smaller damper that will close that gap by moving it closer. I "hear" that for my engine (mild build for cruising with roller rockers & cam) that the smaller damper can be used successfully, but I'm certainly no expert (see line one of this post
). I'll have to do more research about the timimg tab applicability and check the new damper's key and marking locations.BTW, I didn't understand your comment about mismatched parts being the "theme of this thread." As the OP, I was just trying to find out if that bolt by the fuel pump was supposed to be there or if it could be safely removed. Now I know and also learned that I lacked knowledge about dampers and timimg tabs
. No harm - no foul...
Is the tab that's on there easily removable? It's hard to tell with the paint and the camera angle. If so, this bolt on tab may work for you with the smaller harmonic damper (perhaps call Zip to confirm). Do you know what your engine was before it was rebuilt?
https://www.zip-corvette.com/69-80-b...b-bolt-on.html
Good luck with the engine install!
Verified that the timing mark on the "new" smaller damper is about 10* ccw from the keyway which I believe to be correct. At 0 on the tab, the distributor rotor is pointing at the #1 lead.
New timing tab is made for a 7" damper, but at least it's closer to my 6.75" one. Will continue to look for a proper tab...
