Bought a project 71 today. The clock works
Old Sep 14, 2023 | 06:07 PM
62corvette's Avatar
62corvette
Default Bought a project 71 today. The clock works
I dragged home a 71 that has been sitting since 1988. Hooked up the battery for the first time today. The original clock, not quartz, works!! I usually get 1-2 years after a professional rebuild, and here’s an original 1971 that’s still working. Somebody in the planned obsolescence division must have messed up.
Old Sep 14, 2023 | 07:47 PM
Greg's Avatar
Greg
Just another Corvette guy
That's good Ju-Ju right there.
How 'bout a few pics of the car?
Old Sep 14, 2023 | 07:52 PM
kansas123's Avatar
kansas123
Old Sep 14, 2023 | 08:20 PM
n2h2o2's Avatar
n2h2o2
What time is it?...
Time to spend some money!
Old Sep 15, 2023 | 08:29 PM
1971CorvetteII's Avatar
1971CorvetteII
You didn't tell us what DOESN'T WORK, wanna sell your clock so you can buy a fancy quartz one.
Old Sep 15, 2023 | 09:24 PM
Mark G's Avatar
Mark G
Lot of times it's just oxidized contact points in the clock too. A simple clean and lube and they often work another year or some months... lol
Old Sep 16, 2023 | 08:44 AM
1971CorvetteII
Have any pictures of these contact points or just how buried they are, can't be to far away as the center console is in pieces at this point
Think I'll put 12 volts to mine today just to waste more time.
Old Sep 16, 2023 | 12:11 PM
62corvette's Avatar
62corvette
No pics of the car yet, but pics of the tank sticker are attached. It will be a fun car to redo.
Old Sep 16, 2023 | 08:48 PM
Mark G's Avatar
Mark G
I had cleaned a lot of clock points back in the day.. we're talking mid 80's here... lol. I worked for a corvette shop and the owner had a whole milk crate of 50's and 60's era GM clocks. I would work on a few at a time as filler work (when restorations were held up for parts, etc). Clean them up. Then he'd sell them at swap meets. I had done many Ford clocks back then too. This is when I was in high-school! LOL.
I don't specifically remember the later model Corvette clocks, but back then clocks were mostly the same concept... Ya have to remove the mechanism from the housing & sliding a piece of fine sandpaper through the contacts several times (thread a long piece of sandpaper through the mechanism to get between the contacts). Apply an ever so slight mount of light-weight lube or graphite to the moving points. If some of the very fine bores of the moving points were egged-out, then if ya can (on some clocks that are worth it)... disassemble further, peen the hole shut (it was usually brass and easy to do with a punch), then hand drill the hole round again. It's all ball bearings! (Fletch??)
Or better yet, send it out to a clock guy....lol!
Old Sep 16, 2023 | 11:46 PM
n2h2o2's Avatar
n2h2o2
Looks like a 425HP 454 (LS6), 3.70 ratio...should have an M-21.
Nice find! Sounds like fun!
Old Sep 17, 2023 | 02:01 AM
Danish Shark's Avatar
Danish Shark
I had a 71 for years and the clock never worked.
I sold the car and then the clock started working, and still works, without the new owner doing anything
Old Sep 17, 2023 | 09:59 AM
n2h2o2's Avatar
n2h2o2
It sounds like time stood still while you were driving your timeless classic!
Old Sep 17, 2023 | 11:08 AM
loup68's Avatar
loup68
Army
Time for a new gas tank from Quanta. Lou.
Old Sep 17, 2023 | 03:32 PM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
LOL Mike… What is that now, three?!
Regards,
Stan Falenski
Old Sep 17, 2023 | 05:07 PM
62corvette's Avatar
62corvette
Actually has the original M22 still in it.
Old Sep 17, 2023 | 05:08 PM
62corvette's Avatar
62corvette
Regards,
Stan Falenski
Yes, it’s a disease. All your fault!😀
Old Sep 17, 2023 | 08:21 PM
n2h2o2's Avatar
n2h2o2
I could be wrong, but I think M21 was standard on the LS6, so you got the upgrade!
Just can't see your tank sticker well in the pics...
I see black vinyl interior...
What else can you make out?
How much can you tell is original on the car?...
Seems like a great find if the condition is good...
Old Sep 17, 2023 | 10:32 PM
62corvette's Avatar
62corvette
Default 1971
Dual disc clutch came with M22 and M22 was an extra $100 in 1971. There were a total of 130 M22 cars. This car has been repainted the wrong color, and the engine has been replaced, but has most of the other good stuff, and is a convertible. There were around 65 LS6 convertibles made in 71, and there are 28 that we know of that have survived. This one was bought very reasonably. Originally warbonnet/black with two tops, t&t, power windows, power steering.
Old Sep 17, 2023 | 10:35 PM
n2h2o2's Avatar
n2h2o2
Nice!
To Bought a project 71 today. The clock works
