Push rods or roller tip rockers
Old Oct 3, 2023 | 07:37 PM
Steve Kistler's Avatar
Steve Kistler
Default Push rods or roller tip rockers
Does anyone know what the difference is between changing roller tip rockers or changing pushrod length to gain hp? I called edelbrock and they said I could get appx 25+ hp by changing to 1617-18 rockers ($500+) and I wondered if you could get same results from less expensive pushrods. Thanks
Old Oct 3, 2023 | 08:15 PM
bonesbrakr's Avatar
bonesbrakr
You are not going to get 25 HP boost from those rockers. Not even 5. They reduce wear on the valve train not necessarily increase power. If you went to 1.6 ratio rockers then yes you will increase power. The amount depends on what your engine setup is.
Do not change push rod length unless the vale train geometry is off. You will cause more problems then you could imagine and even break pieces or kill the engine.
Old Oct 3, 2023 | 08:27 PM
Steve Kistler
[QUOTE=bonesbrakr;1607106169]You are not going to get 25 HP boost from those rockers. Not even 5. They reduce wear on the valve train not necessarily increase power. If you went to 1.6 ratio rockers then yes you will increase power. The amount depends on what your engine setup is.
Do not change push rod length unless the vale train geometry is off. You will cause more problems than you could imagine and even break pieces or kill the engine.[/QUOTE
I really didn’t believe the person at Edelbrock which is why I asked on the forum. Thanks for replying
Old Oct 4, 2023 | 08:06 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
The Comp roller tip units are a solid upgrade as the stock rockers can be anywhere from 1.4 to 1.5 ratio.......they are worth power to a stock setup albeit only a few....maybe 10hp depending on how shitty the original rockers are.....
The advice on pushrods is correct.....different length pushrods do not change lift or enhance anything.
This hobby is chock full of misinformation.....coming from "Legends" to the suppliers to keyboard warriors on FB......Edelbrock should be reprimanded for saying **** like that.....
Problem is that the stubborn novice will adopt a "Why would the manufacturer be wrong or lie to me?" type of stance.....and nor I or anyone is able to help people like this.......its kinda terrible and frustrating.
Jebby
Old Oct 4, 2023 | 09:10 AM
1972bluelt1's Avatar
1972bluelt1
Push rod length will determine where the roller tip contacts the valve tip.
From my experience, stock length pushrods should be right on the money
on a stock engine.
Old Oct 4, 2023 | 09:15 AM
HeadsU.P.'s Avatar
HeadsU.P.
Back in 6th grade, the teacher was explaining how just one sentence could get so obscured in transferring. As a demo, he whispered about a ten-word sentence to a student, and they were to "pass-it-on" to the next student. By the time phrase got all the way around the room, it was so mucked up that the entire class broke out in laughter. And each student claimed: I never said that!
Edelbrock might have said: Two-point-Five Horse Increase. (But never 25)
Old Oct 4, 2023 | 11:07 AM
Steve Kistler
You sir may know a lot about a lot of things but since I am the one who spoke to the young man @(800)416-8628. I gave him all of my information on my engine and he said “with the 1617-18 rockers you could gain up to 25 hp”.
Old Oct 4, 2023 | 12:21 PM
PBF777's Avatar
PBF777
The "Tech-Lines" are full of unknowing novices these days, and who in this case probably just has drunk to much of the cool-aid!
Scott.
Old Oct 4, 2023 | 12:53 PM
redwingvette's Avatar
redwingvette
I like the way people say “up to” in regard's to hp increase. It’s a good selling point but never true.
air cleaners, power chips, and other performance enhancements are sold saying they are better but few do anything more then take your money.
just add a few stickers and you might go faster.
Old Oct 4, 2023 | 02:59 PM
Sayfoo's Avatar
Sayfoo
Marketing, internet "truths", forum garus, etc., can really mess you up. It's good to ask, but hard to sift through all the bs.
My $.02.
Roller tip rockers have been proven to provide little to no advantage. I saw a youtube video where it showed the roller tip just sliding over the valve stem tip, not rotating. Maybe just this engine or most or all??
Anyway, my '08 436hp ls3 engine does not use roller tip rockers. It does have roller rocker piviot shafts.
New rocker arms?
I seriously doubt that you would get or notice any improvement. Waste of time and money as long as yours are not broken.
Old Oct 4, 2023 | 06:27 PM
HeadsU.P.'s Avatar
HeadsU.P.
Well, ok. I will give you and some Eddy phone tech expert the benefit of doubt.
With a SBC bored, stroked, 11:1 pistons, knarly cam, headers, 64 chamber / 200 cfm heads, and a 780 CFM Holley carb, then yes.
You might gain 25 horse.
Stock or near stock engine. Not going to happen.
If it were that easy, GM would have done it 50 yrs ago.
Old Oct 5, 2023 | 07:45 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
My $.02.
New rocker arms?
Yes, the roller tip isn't that important but the correct ratio and 2x stronger construction is........the HD roller tip stuff picks up a little on a stock engine but enough to warrant the cost......maybe not.....but it does allow support for future upgrades......all depends on whatcha want to do.....I use them a lot on mild builds as I won't put a BS rebuilder stamped rocker arm on a new build......
Jebby
Old Oct 8, 2023 | 01:48 AM
ramair_bryan's Avatar
ramair_bryan
Likely OP was talking to AI...................
Old Oct 8, 2023 | 08:09 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I could see a performance engine with a small cam gaining 25hp with a rocker change....from a 1.5 to a 1.7....but not a stamp to roller tip.
Old Oct 8, 2023 | 12:14 PM
MelWff's Avatar
MelWff
I read through this thread and putting aside what works or doesn't work, the phone number listed is for Edelbrock but the part number listed looks like a Competition Cams number but they don't have a part number with a -18 suffix. So what am I missing here? Did the OP call Edelbrock concerning another companies product and where was that part number found?
Old Oct 10, 2023 | 12:26 PM
PBF777's Avatar
PBF777
Comp-Cams has been folded into the Edelbrock group; so now the chances of finding anyone of knowing capacity just got less likely!
Scott.
Old Oct 10, 2023 | 01:23 PM
MelWff's Avatar
MelWff
Scott.
OK, so what about the part number, can you find it?
Old Oct 10, 2023 | 01:38 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I think that was a typo......1617-16 is a 1.52 Pro Magnum Full Roller for 3/8 stud.......
Jebby
Old Oct 10, 2023 | 02:48 PM
1972bluelt1
Jebby
Yep, I have a set of those on a 377.
To Push rods or roller tip rockers
