Tach stopped working
Old Oct 10, 2023 | 06:50 PM
69XR7's Avatar
69XR7
Default Tach stopped working
If it’s not one thing it’s another. Just finished complete rebuild of steering, suspension, brakes….got the new brake booster in and re-installed the drivers seat.
10 miles into the first drive…
Old Oct 10, 2023 | 08:06 PM
69XR7's Avatar
69XR7
I read a few posts about new tachometer cables being too long. One said the correct length was 20.5”
So far I’ve found zip has 24”, Corvette central has 23” and Top flight has 22” - interesting enough the price goes up as the length gets shorter
Does anyone know the true correct length and if they are available anywhere else?
Old Oct 10, 2023 | 10:21 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
The GM parts books list the '69-'74 cable and casing sheath at 20.66".
You can get replacement cables through general auto parts stores. They are universal cables that are supposed to be cut to length with a square drive tip that is glued on. Use your old one as a length template.
Old Oct 11, 2023 | 07:58 PM
69XR7's Avatar
69XR7
I’m pretty sure my current sheath/cable is one of the too long aftermarket cables. So I’m looking for the entire assembly.
Old Oct 11, 2023 | 10:58 PM
barkingrats
Perhaps going with a good condition used one is the way to go. There are a number of guys offering used parts who may have just what you're looking for - though I can't recommend anyone specifically. Perhaps others here will suggest sources.
Old Oct 12, 2023 | 10:29 AM
sunflower 1972's Avatar
sunflower 1972
This place is pretty popular with the C2 people on the forum: https://deluxespeedometer.com/services.html
Old Oct 12, 2023 | 08:29 PM
69XR7's Avatar
69XR7
Thanks fro the link. I’ll check it out
To Tach stopped working
