Gas Smell
Old Oct 13, 2023 | 08:40 PM
SR75's Avatar
SR75
Default Gas Smell
My 1975 has all the sudden gotten a super strong gas smell when I shut it off. Have checked carburetor (Holley 600) and nothing seems out of the ordinary. The only thing I see that is questionable is that the fuel filter (plastic WIX see through) has barely any gas in it, around 1/4 of the way full), when its running. Any ideas?
Old Oct 13, 2023 | 09:58 PM
n2h2o2's Avatar
n2h2o2
Check your charcoal canister...
Old Oct 13, 2023 | 10:18 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
When you turn off your car look into the carb & see if there is any fuel dripping ?
Old Oct 13, 2023 | 10:25 PM
SR75's Avatar
SR75
I got rid of all the smog equipment and the vacuum line going to the canister, I could be wrong but this would make it non-functional right?
Old Oct 13, 2023 | 10:45 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Unless you have an obvious fuel leak at the fuel tank, pump or carb, strong fuel odor is usually something to do with the EVAP vapor system. n2h2o2's suggestion to look at the charcoal canister (engine compartment behind the driver-side wheel well) is just part of the EVAP system, so more needs to be inspected.
  1. With a flashlight, inspect under the gas tank on the driver's side. You're looking for signs of fuel seeping down the side of the spare tire carrier and/or on top of the muffler. If you see signs of this, it's likely the fuel separator "valve" mounted to the upper corner of the tank. These are prone to splitting of the housing or internal failure of the baffle. It separates liquid fuel from tank vapors.
  2. The tank vapors are pulled to the engine along the frame rail to the charcoal canister. The PCV system pulls the vapors to the carb where they are burned off. If the separator isn't working correctly, the canister can get contaminated with liquid fuel which saturates the charcoal. Check the hoses at the canister to ensure they are snug on the nipples - maybe cut 1/2" from each to get a non-stretched segment and reinstall.
  3. If the above doesn't yield any strong suspects, inspect your gas cap (it should be marked non-vented) and its gasket seal under the lip.
Old Oct 13, 2023 | 10:47 PM
barkingrats
Saw this reply after I typed up my previous reply but didn't want to delete it all and start over...
Did you remove the separator on the tank or at least cap off the nipples?
Old Oct 14, 2023 | 12:29 AM
SR75's Avatar
SR75
I did not, when I dropped the tank in July-ish of last year to replace the sending unit I just hooked the old hose back up. I did run new supply and return rubber lines though. The only fuel lines that haven't been replaced besides the evap lines are the rubber lines from the frame to the pump.
Old Oct 14, 2023 | 05:11 AM
Mr D.'s Avatar
Mr D.
Unless you have fuel pooling in the intake after shutdown or an obvious leak the culprit is most likely the E.E.C. Valve (Separator Assembly) that is mounted at the top of the fuel tank on the left-hand side. The ball inside gets stuck allowing fuel to get into the vapor canister and that is what you're smelling.
I haven't read anything good about the repop E.E.C valve the vendors sell.
Old Oct 14, 2023 | 07:53 AM
HeadsU.P.'s Avatar
HeadsU.P.
On some Holleys a metering block gasket, a fuel bowl gasket and sometimes the accelerator pump gasket can weep. Not dribble. Weep.
You can get a strong gas smell at shut-down but no visual of drips. The only clue is, again sometimes, a gas stain under the carb.
Not my car but, why do you feel the need to know if gas is flowing through the lines?
Those plastic or glass in-line filters are mauldov cocktails waiting to go off.
Those gas bombs should only be sold as a kit: One Filter, Two Hose Clamps and One Fire Extinguisher.
Old Oct 14, 2023 | 09:48 AM
grady white's Avatar
grady white
get rid of that plastic fuel filter immediately.. run a hard line to the carburetor
Old Oct 14, 2023 | 09:49 AM
grady white
well said heads-up 👍
Old Oct 14, 2023 | 12:16 PM
SR75's Avatar
SR75
I've only heard that about the glass filters, didnt know the plastic ones were just as bad. I'm rebuilding a Quadrajet for it that will utilize the factory hardline here soon so I reckon I wont have to worry about the filter any more. Thanks for telling me that, I assume the metal filters are best?
Old Oct 14, 2023 | 01:03 PM
barkingrats
If I'm understanding, you reconnected the vapor lines (driver's side) at the tank/valve to the frame rail's hard line that runs to the canister but no longer have the canister and capped the line there? You could still have valve failure at the tank so that fuel is leaking there.
Did you, by chance, have a spirited drive with a fairly full tank before you noticed the fuel smell? If so, the separator valve is likely the culprit.
Old Oct 14, 2023 | 01:11 PM
SR75's Avatar
SR75
The canister is still connected there just isn't any vaccum lines going to it anymore. Yeah I had just filled up yesterday and noticed it that afternoon.
Old Oct 14, 2023 | 01:41 PM
barkingrats
I just noticed that '75 doesn't use the separator valve - that stopped in '74 - I assumed it had one. I'll bow out and let someone more knowledgeable with the '75 setup address how the vapor line may allow fuel to the canister.
Old Oct 14, 2023 | 04:38 PM
Mr D.'s Avatar
Mr D.
Found this, not 100% sure how it works but next thing to do is remove line from canister and see if it's wet.
To Gas Smell
