A new one for me!
Old Oct 30, 2023 | 03:18 PM
randallsteel's Avatar
randallsteel
Default A new one for me!
I went to start the vette this morning; cranked like normal, engine fired off, but immediately heard grinding from the starter! I turn the key off and lo and behold, the motor keeps cranking!
I rush and disconnect the main line off the battery. By this time the post is hot to the touch.
visually I don’t see anything the matter, but I’ll take the starter off and do some continuity checks tomorrow. I’m assuming something internal failed.
Glad nothing caught fire. Cranked for close to a minute
Old Oct 30, 2023 | 03:58 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
It's most likely a bad starter solenoid. Had the exact same situation with my 65 last year. I replaced the starter and solenoid.
It is a bit of a panic situation. Fortunately, the ring gear (fly wheel) wasn't damaged. Starter drive was destroyed.
Old Oct 30, 2023 | 05:16 PM
randallsteel
I just checked, resistance from solenoid terminal to the main terminal is 11kohm. Not sure what to make of that, but it’s not a dead short between the two.
Old Oct 30, 2023 | 06:54 PM
kanvasman's Avatar
kanvasman
I go with bad solenoid.
Old Oct 30, 2023 | 07:58 PM
HeadsU.P.'s Avatar
HeadsU.P.
Starter is likely ok. No need to run out and buy a $250 mini.
When you have the starter out, swap to a brown end cap solenoid. Those perform much better around heat. The brown ones are ceramic.
Put a dab of grease on the Bendix / shaft.
Might want to consider a battery shut-off switch for just these occasions. And prevents any parasitic draw.
Old Oct 30, 2023 | 08:11 PM
randallsteel
It’s actually a GM mini lol
If it is bad I’ll try off brand made-in-china next. 1/3 of the price!
im going to do some testing tomorrow. route just 12volts to the solenoid, with main lug disconnected and see what happens
Old Oct 31, 2023 | 01:35 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
100% the solenoid......the solenoid does two jobs at the same time....it pushes the gear out....and it makes contact from the always hot starter lug to the one right below it which is the motor lead.......if the motor is stuck on, then the solenoid is stuck in the out position.....remove solenoid and look for corrosion or anything else that will make it hang up.....
Gotta get rid of those hang ups man.....LOL....
Jebby
Old Oct 31, 2023 | 01:46 PM
randallsteel
Yeah something internal musta failed.
I did some controlled testing with 12v just to the solenoid and then some with battery connected to main terminal. First try the bendix threw out, but I couldnt replicate the run-on issue, after a couple tries the starter would just spin without throwing out at all.
Assuming something failed and then the one minute constant cranking further degraded it.
New mini is on the way
To A new one for me!
