Need help
Old Nov 3, 2023 | 10:59 PM
Wallace Lindsey's Avatar
Wallace Lindsey
8th Gear
Default Need help
Looking for help to take slack out of my stearing wheel.
when I turn it has about 3 inches before it starts turning.
I have 1979 c3 corvette
Old Nov 3, 2023 | 11:06 PM
righthanddrive's Avatar
righthanddrive
Check all your rubber bushings on the front end, and the rag joint that connects it to the steering box.
If all else fails , have someone turn the steering wheel while you inspect under the car. MAKE SURE you don't have it running and probably block the wheels in back , so you don't get run over
Old Nov 3, 2023 | 11:21 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
rag joint / rebuild box = usually cures all !!
Old Nov 4, 2023 | 07:13 AM
Bikespace's Avatar
Bikespace
Put it on ramps, and with an assistant, turn the wheel back and forth while filming the steering box and rag joint (from above), and all of the steering linkages (from below).
Post videos on YouTube.
Then fix what's wrong.
To Need help
