383 stroker camshaft
Because the car is heavy in vacuum, what should I look for in a camshaft? I want to be able to drive it on nice days, and won’t be using it for racing or anything, but I wouldn’t mind my stoplight to stoplight having a good kick. Also, if it’s possible to have a bit of good sounding chop.
If you're going to go with a flat tappet, the Comp Cams Magnum 280H grind is probably the best choice out there for a moderate (400'ish HP) 383 build, as any lift duration at or over 230/230@.050 (which it is) is consider a hot number without being TOO radical. It's the most radical you can go without the car seeming like it's going to shake to pieces at idle. I love that grind. Basically a L46/L82 grind on steroids. Any higher than a 280H and you'll have vacuum issues at idle, and streetability issues. Low end torque on the radical cams - gone....
Also, with flat tappets you HAVE to make sure you are running oils with sufficient levels of ZDDP (1100 PPM or more) or you'll shave a lobe....I know this from personal experience, or you need to run ZDDP additives. If running a roller, you don't have to worry about that and you can get similar profiles, but they are much more expensive.
This is my opinion, so per usual, wait for additional input from other members, but also do your due diligence and gather research from multiple reputable sources before making a decision.
Hydraulic Roller Camshaft & Lifter Kit; 1955 - 1998 Chevy 262-400 1800 to 5400 Howards Cams CL110245-12S | Howards Cams
Jebby
Jebby
