C3 Ride Height
Old Nov 27, 2023 | 05:09 PM
jimy's Avatar
jimy
Default C3 Ride Height
As I gather information on C3's for a future purchase, I looked at one over the weekend. It was a 78. The muffler clamp couldn't be much more than 2 1/2" off the ground. Super low. Is that just a wore out suspension?
Old Nov 27, 2023 | 06:03 PM
Ed Johnson's Avatar
Ed Johnson
Could just be a I’ll fitting exhaust system. If you stand back from car and car seems level, it’s likely the exhaust. There are so many reproducers of exhaust that do not do a good job bending pipes. And also people that just do not know how to install.
Old Nov 27, 2023 | 06:30 PM
Bikespace's Avatar
Bikespace
Did you take any pictures?
Perhaps knowing what color the car was would help us guess the cause.
Old Nov 27, 2023 | 10:25 PM
SEVNT6's Avatar
SEVNT6
If you mean the clamps forward of the mufflers I made a little more clearance by putting them nut side up. Also looks cleaner...
Old Nov 28, 2023 | 09:16 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Look at the car....does it look like it is sitting low? 78-79's sit high in the front from the factory and have a "dog squat" look to them......forget the muffler clamp, how does the car sit?
Jebby
Old Nov 28, 2023 | 10:13 AM
grady white's Avatar
grady white
Jebby
check your spring bolts . They should be 6 5/8 long from factory . Could be PO installed ling bolts that would lower the height
Old Nov 28, 2023 | 10:15 AM
Bikespace's Avatar
Bikespace
Post the sale link if you need to. The low stance could be a sagging rear spring, or intentional, or exhaust, or who knows what.
To C3 Ride Height
