Seeking recommendations for ‘69 drivers side mirror
I see that a replacement driver’s side mirror plus mounting kit is more or less $50 from the various suppliers, e.g. Zip, Corvette Central, RPI, etc. Perhaps they all come from the same assembly line, but I thought I’d ask here first for recommendations and suggestions.
This might be a silly question about installation, but…if the existing rubber gasket and mounting hardware are in good condition, is it still preferable to use the new mounting hardware that will come with the kit, instead of reusing the old?
I saw the online mirror replacement tutorial on Zip’s website, and the project is rated a 1 out of 5 in difficulty, so I’m feeling that I can do this myself.
Thanks, everyone!
After today’s drive, just as the sun set.
I see these are date coded.
https://www.corvettecentral.com/c3-6...26years%3d1969
I just got a non-date coded mirror. I think it’ll be an improvement.
I did this to mine several years ago and it still works fine. AIso is also much cheaper than a new mirror, and if it doesn't work like you want you can always buy a new one.
Thanks, everyone!
Tape a towel or wax paper to the car under the mirror to stop any drips if you get sloppy.
Get in the car and set the mirror to the position you want
open the door gently but do not close it.
Put thick crazy glue on the mirror ball
Let it set.
If you want more firmness, gently unscrew the entire mirror and put crazy glue into the hole for the ball, not a lot , jist a little.
Lasts about 2 to 3 years
I use it on my 67, 71 and 72
The replacement mirror has shipped already, so I’ll see how it looks when I get it. My existing mirror is pitted on both the mounting stalk/arm (whatever it’s called) and on the mirror surround housing itself. When I looked up the date code for the mirror, it appears to have a 1973 date. I’d be more likely to repair it if it were original. Regardless, I’m not going to toss what’s presently on the car.
The rear view mirror is silvered, so I’m tempted to swap that out, too. But, at least it works.
Check this out. Not cheap but looks like a straight up solution. https://www.corvetteforum.com/forums...post1602949851
