Battery issues
Old Dec 1, 2023 | 01:07 PM
Hig116's Avatar
Hig116
Default Battery issues
***SOLVED***
This feels like a dumb question, but I’m going to ask it anyway. My battery loses charge when it is disconnected. I had it tested at AutoZone, and they told me the battery was good. Can the battery test as good but still lose charge, if not connected? I have a quick disconnect on my positive terminal and leave the negative terminal connected. Is there some way it’s losing charge being connected to the negative terminal? Again, this seems like a dumb question.
Before I buy a new battery, I wanna make sure it’s not a problem other than the battery.
thank you
Old Dec 1, 2023 | 04:11 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
The one thing you left out was the amount of time it takes to loose charge.
All batteries will lose charge over time.
Is it going flat over night? And your certain your disconnect is disconnecting?
Is it going flat in 3 months?
If it's going flat disconnected in under a week, yes I would purchase a new battery.
Old Dec 1, 2023 | 04:29 PM
Hig116's Avatar
Hig116
Sorry, that is important. It goes dead under a week.
Old Dec 1, 2023 | 04:44 PM
kansas123's Avatar
kansas123
As pointed out, might need to replace it. Any idea how old that battery is?
Old Dec 1, 2023 | 04:51 PM
Cool95vette's Avatar
Cool95vette
Try changing the disconnect to the negative terminal
Old Dec 1, 2023 | 08:18 PM
4-vettes's Avatar
4-vettes
How could that possibly change anything? If it's disconnected, it's disconnected.
Old Dec 1, 2023 | 09:07 PM
lickahotskillet's Avatar
lickahotskillet
Is the top of battery damp & dirty?
Old Dec 1, 2023 | 09:14 PM
Hig116's Avatar
Hig116
Nope
Old Dec 2, 2023 | 08:15 PM
MelWff's Avatar
MelWff
Exactly how did Autozone test it? You left the battery with them so they could fully charge it and then they load tested it?
Old Dec 3, 2023 | 09:31 AM
Hig116's Avatar
Hig116
Is this something AutoZone offers? The will keep you battery, charge it and then test? I didn't know this or do this if they do. I just handed them the battery and they put their battery tester on it. In fact, it was NAPA, not AutoZone. They told me it had good cranking amps and just needed a charge.
Keith
Old Dec 3, 2023 | 10:08 AM
MelWff's Avatar
MelWff
Keith
In your initial post you stated autozone. You have to fully charge a battery before load testing it.
Old Dec 3, 2023 | 10:49 AM
Eliredandblack's Avatar
Eliredandblack
I had a NAPA branded battery tested at my local NAPA store with their little hand held tester, guess what? They gave me the same story, battery was good, only needed charging. Oh, did I mention that is was still under warranty. That was the las time I purchased a battery from NAPA. I wonder . . . if the battery was out of warranty, what would they have told me?
Old Dec 3, 2023 | 12:04 PM
Bikespace's Avatar
Bikespace
When they tested it, they tested capacity, not self discharge.
Perhaps you can save it with a desulfating charger. But it might be easier to replace it.
Are you 100% sure it is disconnected fully, and still discharging? It is not uncommon for diodes to fail in your alternator, which will kill a battery in a day or three. I only ask because the alternator circuit does NOT go through your fuse box, and I haven't seen any pictures posted in this thread.
Old Dec 3, 2023 | 01:18 PM
MelWff's Avatar
MelWff
You can test the alternator for bad diodes with a AC voltmeter. With engine running the alternator should output zero AC volts.
Old Dec 3, 2023 | 03:11 PM
Hig116's Avatar
Hig116
I marked this as SOLVED as I decided to buy a new battery. I had the battery on charge all day yesterday (trickle) and it was working fine. I accidentally knocked the charger lose from the battery and this morning the battery was dead. Well, not dead, as it showed 11.7 volts, but it would not turn over the engine.
So I thew in the towel and just bought a new battery. Problem solved for now.
Thanks to everyone who took the time to respond and offer their thoughts. I appreciate it.
Keith
To Battery issues
