Hood Grille Nuts
Old Dec 1, 2023 | 05:01 PM
L8T2's Avatar
L8T2
Default Hood Grille Nuts
I’m trying to find a set of ‘73-‘76 hood grille nuts (GM part no. 9420621) NOS or good used. They have rubber cushion inserts on the underside. I haven’t come across any repros and the replacements sold by the usual suppliers are acorn nuts that look nothing like the correct part. Here’s what the originals look like:
Any tips would be much appreciated.
Old Dec 1, 2023 | 05:14 PM
n2h2o2's Avatar
n2h2o2
https://oldsobsolete.com/products-pa...t-nos-9420621/
Old Dec 1, 2023 | 05:44 PM
L8T2's Avatar
L8T2
That’s where I got the photo. Two concerns: the one example shown is pretty rough-looking and it wasn’t clear whether there was more than one for sale. I’d like to find a set without the rust. Thanks for trying to help.
Old Dec 1, 2023 | 07:08 PM
n2h2o2's Avatar
n2h2o2
This is probably the closest you will find for new.
https://www.ebay.com/itm/13304752752...Cclp%3A4429486
Old Dec 1, 2023 | 08:11 PM
L8T2's Avatar
L8T2
Very close. They are described as “thread cutting” and are to be used with “smooth studs”. I’ll take a look at the studs on my hood and see if the threads on them appear to have been cut by the nuts when they were installed. If they are a standard thread — say 3/16-20 — then these nuts might not work. But I’m betting they will. Thanks for finding these, and thanks for introducing the term “thread-cutting nuts” to my vocabulary.
Old Dec 2, 2023 | 10:50 AM
Duke94's Avatar
Duke94
9420621 is about 1/2 way down.
https://www.amkproducts.com/bulk-fas...forlookup=7165
Old Dec 2, 2023 | 11:29 AM
Dagious's Avatar
Dagious
A trick I learned is to set the nut over the stud, then turn it counterclockwise (lefty) slowly applying slight pressure. You will feel a click. This is the threads lining up with the nut. Slowly start to tighten. If there is little resistance, you’re following the existing cut threads. If not, you’re cutting new ones.
this has worked for me multiple times.
Old Dec 2, 2023 | 12:44 PM
L8T2's Avatar
L8T2
Originally Posted by Duke94
It’s not clear whether they have the rubber inserts, but the price is right. Thanks.
Old Dec 2, 2023 | 12:46 PM
L8T2's Avatar
L8T2
Thanks for the tip. 👍
Old Dec 8, 2023 | 05:38 PM
Mikey857's Avatar
Mikey857
Mine on my 73 big block hood are acorn style nuts, not open like this
Old Dec 8, 2023 | 05:42 PM
Duke94's Avatar
Duke94
I think the black stuff isn't a rubber gasket but some kind of sealer. It should call it out in the Assembly Manual.
Old Dec 8, 2023 | 05:53 PM
Mikey857's Avatar
Mikey857
I just ordered these for my 1973.
1973-1976 Hood Grill Acorn Nut 8 Piece Mounting Kit
SKU: 609513
$4.99
Old Dec 8, 2023 | 07:51 PM
L8T2's Avatar
L8T2
SKU: 609513
$4.99
I’m not an authority (NCRS judges feel free to weigh in here), but I believe that you may lose originality points for using acorn nuts under strict judging if the thread cutters turn out to be the right part. Anybody out there have a completely untouched original ‘73-‘76 and care to comment?
Old Dec 8, 2023 | 08:03 PM
L8T2's Avatar
L8T2
By Jove, you are right. I went back and pulled this quote from the site linked above by n2h2o2
You are buying one (1) NEW assortment. This assortment contains forty five (45) (see sizes below) zinc plated thread cutting nuts with mastic sealer that can be used on Buick, Cadillac, Chevrolet, Oldsmobile, Pontiac & GMC vehicles.
Mastic sealer it is.
Old Dec 9, 2023 | 08:35 AM
Mikey857's Avatar
Mikey857
One were original acorn nuts. I was missing one is why I ordered the set
Old Dec 9, 2023 | 10:03 AM
L8T2's Avatar
L8T2
If you are the original owner and your car has never been repainted, that’s a really helpful input. Otherwise there’s no way to know if your acorns are original without some more authoritative info. I’m not sure that this minor detail is worth anymore back-and-forth. As Bob Dylan sang, “you go your way and I’ll go mine.”
Old Dec 10, 2023 | 02:35 PM
Blue73Shark's Avatar
Blue73Shark
According to Section 8 "Hood and Vent Grille" on page 77 of the 2018 3rd edition NCRS 1973-1974 Corvette Technical Information Manual and Judging Guide, "Six (6) black phosphate-plated acorn nuts secure the underside of the grille". Fig. E 8.1 on the same page shows them.
Fran Giacoma
To Hood Grille Nuts
Old Dec 10, 2023 | 05:49 PM
L8T2's Avatar
L8T2
Fran Giacoma
Thanks, Fran. That’s an authoritative confirmation of Mikey857’s input about the acorn nuts (at least for the ‘73-‘74 model years — no reason to believe the ‘75-‘76 are any different). It seems that the original black phosphate nuts are discontinued (https://www.corvettecentral.com/c3-6...-pieces-343045) but chrome facsimiles can be had (https://www.motorcityvettes.com/exte...-set-1973-1976). Nothing a spray can can’t fix.
Old Feb 3, 2024 | 02:24 PM
kabuelich's Avatar
kabuelich
My early unmolested 73 has threaded studs on the grille and acorn nuts
Old Feb 4, 2024 | 10:04 AM
LT-1 kid's Avatar
LT-1 kid
yes those nuts are most definitely acorn type speed nuts
