Wiper motor
Old Dec 3, 2023 | 06:09 PM
JC Pilcher's Avatar
JC Pilcher
Default Wiper motor
Hello Everyone, new to this forum. I just purchased a 1969 Vette Conv that I’m very excited about. The car has several upgrades but need a lot of work. So it’s not a numbers matching car so I’m going to make it how I want it. It has a BB 468 with a 4 speed. Came with a L88 aftermarket hood I’m assuming. The hood comes all the way to the windshield. So I won’t be needing the vacuum or pop up grill. My question is what wiper can I use as there is no need for the original wiper set up as the hood covers the wipers. Also want to run the squirters along with it. I appreciate the help.
Old Dec 3, 2023 | 07:50 PM
Mooser's Avatar
Mooser
Do you have the original wiper motor? If you simply bypass the wiper door switch (red wire) it will work fine. Otherwise look at a 73+ style
M
Old Dec 3, 2023 | 07:59 PM
JC Pilcher's Avatar
JC Pilcher
Yes I have the original motor but I don’t think it works. I need a new wiper switch. Probably just replace it with a 73 like you mentioned. Thanks for the info.
Old Dec 3, 2023 | 08:08 PM
Mooser's Avatar
Mooser
Also remember that the wiper switch must be grounded for it to work. You can also bypass the tach-solenoid behind the dash that controls the vacuum to the door but it doesn't really matter
M
Old Dec 3, 2023 | 08:41 PM
JC Pilcher's Avatar
JC Pilcher
Thanks Mooser. I appreciate it. Going to bench test it and see what’s what.
Old Dec 4, 2023 | 02:44 PM
Richard454's Avatar
Richard454
Oh- make sure to check this as well- if it's plugged in backwards....
Old Dec 4, 2023 | 04:53 PM
JC Pilcher's Avatar
JC Pilcher
Thanks Richard, good to know. Appreciate it.
To Wiper motor
