Aluminum Radiator Core Support Question
Not sure if this makes a difference, but I want to replace my core support because it's rusted and cracked at the bottom corners. I appreciate any advice you guys have.
Application note: This radiator was used on 1969-72 small block Corvettes equipped with factory installed options. These options could include an automatic transmissions, air conditioning, or special engine options such as LT1 and L46. Base cars (with no options) used a smaller radiator with the separate surge tank.
If you have a base engine car, you have the wrong radiator. Going through their C3 page, I found this.
https://www.dewitts.com/collections/...eries-radiator
Read the fine print from their website
Options:
Call Dewitt’s and arrange for an exchange. You’ll need to decide if you can repair your existing support or replace.
Keep what you have and swap out the core support with one from Coffman Corvette. 419-522-4226. This radiator does not use the surge tank so you’ll need to replumb some hoses. Not a big deal.
I installed my DeWitts 3 years ago. Here's a photo from Sept. 2023 of the gauge cluster after sitting running on high idle, IN MY GARAGE, after 30 minutes.
Here's what the OP's link goes to.
I already tossed the old radiator. I don't remember seeing brackets towards the top corners to hold it in place. I could be wrong, but I think it only attached with one support at the top middle or bolts at sides. I can take pictures of the core support on my car after work, but this is what it looks like. I know it has the thin black panels that extend in from the sides.
I emailed the original rep that made the suggestion. If I don't hear back from him soon, I'll reach out over the phone. I just want to make sure I know what to ask for. The car is a cruiser. I'm not looking to race it. Just looking for it to be as reliable as possible for an older car.
You have two radiator choices when it comes to the type, 1) the type you have that utilizes a surge tank and 2) the type that does not. To me, the most logical choice for you is to stay with the surge tank type and exchange the radiator with DeWitts.
However, you have another, related issue and that is the condition of the core support. I would recommend you first decide what to do with the core support. If it is repairable, fix it. If not, replace it.
If you decide to replace it, as you already have a non-surge tank radiator in your possession, you have the opportunity to buy a compatible support, remove the surge tank, and off you go. Or, buy the same style support as you have and exchange the radiator.
Word of advice - don’t attempt to do a Bubba job of cobbling up a frankenradiator/core support combination.
The fans, though, will require wiring, and possibly a new alternator, to work properly and safely. Hopefully your Hot Rod family member can help with that. Your car will thank you, with or without AC.
Paragon lists the parts but the lower mounts are welded on, uppers bolt on
I spoke with a different rep at DeWitts today and he was very helpful. They will allow me to return the wrong radiator for the correct one since it was never installed and I may also be able to get their recent Black Friday pricing on the new one. At first the rep was confused because his system didn't show '72 SB manuals as having air conditioning. But when I explained that my car has an expansion tank and the core support has the black inserts extending in from the sides, he said the smaller radiator with only one fan is the one that fits. He also said that since my new engine is only pushing 340 HP and runs on 87 octane, the smaller correct radiator will provide plenty of cooling. This car is my weekend ride. It allows me to relax, think about my dad, and sometimes drag my daughter along for an ice cream run in style. When I want to have a little more fun through the twisties, I'll take my GTI.
The Vette is not matching numbers and I'm pretty sure it was in a front-end collision at some point before my dad bought it. I replaced the heater core a few years ago and recently pulled out the AC coils and massive casing that surrounded the blower motor to get ready for the AC box delete. All that pointed towards a car with OEM AC. I know for a fact that it's not an LT-1, but I remember my dad saying the previous owner told him he built it up to be "like" an LT-1... whatever that's supposed to mean. Combine that with the fact that it had leftover wiring from 4 different alarms, I sometimes struggle to know what originally came on the car and what was pulled from someone's parts bin.
After reading everyone's advice and talking with the rep from DeWitts, I think I'm going to go with the smaller radiator that fits my current core support. I've attached a few pictures of my core support. I think it looks like this one from Corvette Central. Based on the cracks and rust in the photos, I'm pretty sure I need to replace it. Both bottom corners look like this. Let me know what you think. I appreciate your input.
Looking at your existing support, while clearly it has rust but it’s not all that bad as it is localized (very common). Certainly have seen a LOT worse. The rest of the support looks fine. You may want to just clean up what you have, remove the rust, paint and apply some rust proofing. That will likely last at least as long as you drive the car, providing, of course, you don’t expose it to salt. A competent welder can repair it but IMO, given your situation, may not be needed, provided you stop the spread.
Ebay has them
Im sure others do to
Volvette https://www.volvette.com/CL103P.html
Coffman Corvette got the original GM dies from us to make these. Lou.
With all the money I’ve spent gathering parts during the past six months, another $80 for what’s hopefully a better part and to support US manufacturing certainly isn’t going to break the bank.
Since you are replacing the support anyway, are you going to use the larger radiator that DeWitts sent you as a happy accident? Or swap for the "correct" OEM style? Either way, good on DeWitts for making right with you.
