The back wall was moved toward the front of the car to give more space to the gas tank in case of a rear end collision. Some people were badly burned from the gas tank smashing the back wall and then the tank cought on fire.
They added a fuel bladder inside of a metal tank shortly after. I think in 1975. Lou.
There is for sure a difference in the heel pad on the carpet if you are judging the car, if you are going for fit... personally if the carpet is longer I find them easier to fit.. hard to add carpet... easy to cut carpet. - I cut carpet using a blade in a soldering iron. that way it will never pull, it is. ALSO what I use to poke holes for seat belts... hot soldering iron.
