1976 Corvette Front Spindles
Old Dec 12, 2023 | 08:11 PM
Ace76c3's Avatar
Ace76c3
3rd Gear
Default 1976 Corvette Front Spindles
Hi all,
so I have a question about the spindles.
is there any spindles that’s available that doesn’t have the shaft for the wheel?
im wanting to upgrade from the original style to the new style that takes the 3 bolt hub/baring
Old Dec 12, 2023 | 09:18 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Isn't the spindle the shaft the wheel mounts to? By definition a spindle is a shaft.
Old Dec 13, 2023 | 09:04 AM
Ace76c3's Avatar
Ace76c3
3rd Gear
The wheel mounts the wheel hub, the hub mounts the spindle. If you look at new style spindles unless they are fwd they don’t have the shaft, a lot of the new style wheels doesn’t have the caps to cover a shaft sticking out like the older style c3 does. The first pic is of the c3 and the second is of a c5.
Old Dec 13, 2023 | 11:42 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by Ace76c3
Hi all,
I'm wanting to upgrade from the original style to the new style that takes the 3 bolt hub/bearing
But is that really an upgrade??
Old Dec 13, 2023 | 12:19 PM
Ace76c3's Avatar
Ace76c3
3rd Gear
Considering that it allows for more wheel choices with out the uses of an adapter I would say yes it would be an upgrade.
Old Dec 13, 2023 | 06:23 PM
leadfoot4's Avatar
leadfoot4
I would think that clearance between the frame, on the inside, and fenders, on the outside, will be the bigger determining factor of wheel width and offset, therefore wheel choice, than the spindles will be.....
To 1976 Corvette Front Spindles
